Go Back   OFFROADSUBARUS.COM > Technical Forums > Bolt-On Bits, Accessories and Protection
  #1
Unread 13th July 2016, 03:00 AM
Vert Vert is offline
Year: 2007
Model: Forester x
Transmission: Auto
Vert is on a distinguished road
Default Subaxtreme bull bar for SG forester is it worth it?
Hello all,
Looking to hear from members who have SG2 model with bullbar, either sg1 or 2.
Just seeing does it really improve off road pros and cons.
The 07 bar looks not as good as the other models for it.
Cheers for any feedback.
  #2
Unread 13th July 2016, 04:44 AM
Year: 2007
Model: Forester x
Transmission: Auto
Dam phones billboard .... bull bar..... good thing there's autocorrect
  #3
Unread 13th July 2016, 05:05 AM
Ratbag's Avatar
Ratbag Ratbag is offline
Year: MY06, MY10
Model: Forester SG & SH
Fixed, mate. Bloody spell chequer ... .
In answer to your question - about 1-3 degrees better approach angle, and far less likely to be damaged like the OEM plastic bar.
Far more importantly to me, it stops any discussion with a roo from taking out the top radiator tank, and worth it for this reason alone IMO.
  #4
Unread 13th July 2016, 05:18 AM
Red XS's Avatar
Red XS Red XS is offline
Year: 2006
Model: SG Forester XS
I put a SG series I bulbar on my SG series II. Only reason I did it was to improve approach angles. The series I bar gives slightly better approach angles then the series II bar.
I had quite a few scrape marks on the stock bumper as well as a tear which was slowly getting larger.
Even ripped it off on a rock once...
But I haven't put any scrape marks on my new bullbar yet. It's touched the sand here and there, but nothing bad like it used to. Hasn't changed the over all off road performance as I never let a bit of bumper scraping stop me ... as you can tell by the above pictures. But it is nice not worrying about it catching on anything. Also it looks way better...
Other Pro's
- Easy mounting for spot lights
- Easy mounting for CB antenna or dune flag
- Increase chance of car being driveable after a roo hit.
- Really light bulbar, no noticeable difference in handling (some steel bulbars on other cars do wreck a cars handling)
Cons
- Have to cut plastic bumper and wheel arch linings to make it fit
- Leaves windscreen washer bottle vulnerable, unless if you relocate it to the engine bay location with a washer bottle from other models.
Overall I'm really happy with it.
  #5
Unread 13th July 2016, 06:26 AM
Year: 2007
Model: Forester x
Transmission: Auto
Yeah was looking at doing the same thing maybe.....
Doing an interstate rural holiday in two weeks so not sure if I will have the time to do.
It gives massive tire angle approach compared to the standard wrap around aluminum sports like bar.
Any links you can suggest for this conversion diy????
  #6
Unread 13th July 2016, 06:28 AM
Year: 2007
Model: Forester x
Transmission: Auto
Originally Posted by Ratbag View Post
Fixed, mate. Bloody spell chequer ... ..
Cheers for that.
  #7
Unread 13th July 2016, 07:03 AM
Liberty Valance's Avatar
Liberty Valance Liberty Valance is offline
Year: 2007
Model: 2 x XT Foresters
Transmission: Auto
Liberty Valance is on a distinguished road
There are several ways to fit a Series I (03-05) SG front bar on a series II (06-08) SG all are acceptable depending on what you want to achieve.
There is the 'easy way' where you keep the whole bar intact and use the factory mounting position which leaves more of your front bumper in place. (see DellsFoz DIY write up http://offroadsubarus.com/showthread.php?t=967&page=2)
There is the 'hard way' where you modify the mounting brackets and cut away a lot of the bar under the headlights. You also modify the air intake and washer bottle. This results in a higher mounting of the bar flush with the guards. You end up with a much improved approach angle but the alloy hoops sit higher than normal (see my car)http://offroadsubarus.com/showthread...ighlight=salty
There is the 'hardest way' which is similar to my method but you make your own alloy hoops, similar to an ARB Sahara bar. (see Findizzles car)
http://offroadsubarus.com/showthread.php?t=6643&page=2 Honestly, I like Fandizzle's method the best but I need the side hoops to mount my fishing rod holders.
MY06 XT Luxury Onroad
MY07 XT Luxury Offroad
  #8
Unread 13th July 2016, 10:05 AM
ateday ateday is offline
Year: 2002
Model: MY03 Forester
Transmission: 5 sp manual
Have had one since about 2004. No complaints at all.
  #9
Unread 13th July 2016, 10:07 AM
Year: 2007
Model: Forester x
Transmission: Auto
Ok so it's only a slightly worse approach angle for the sg2.
So far I see that it offers more protection to engine bay area. No need to do a washer bottle mod and I keep my airbag rating for insurance if the worse was to happen.
Faster fitout for trip. Lol
I like the extra tire clearance on the sg1 though.
Maybe I should just call it at the sg2 purely on the airbag rated for my 07....
  #10
Unread 13th July 2016, 10:39 AM
Year: 2007
Model: Forester x
Transmission: Auto
I hope you talking about the sg1 unit lol
Looking at doing the bar for an 07 forester.
