Go Back   OFFROADSUBARUS.COM > Technical Forums > Bolt-On Bits, Accessories and Protection
  #11
Unread 22nd May 2013, 06:30 PM
Brumby Boy's Avatar
Brumby Boy Brumby Boy is offline
Brumby Boy is on a distinguished road
idw, I sprayed them with an etch primer in a rattle can, my brother painted them black using "Rust Not" black from a rattle can.
He has changed his mind and bought Superior Engineering front long arms, basicle the same as these but 125mm longer, so these arms are now going in my patrol.
He who dies with the most toys wins.
  #12
Unread 22nd May 2013, 06:32 PM
Brumby Boy's Avatar
These are some engine mounts I made for the Holden 308 engine to go into my Patrol.
And this is the gearbox cross member I notched to make clearance front the front drive shaft.
gotta love the iPhone pictures lol
  #13
Unread 20th July 2013, 02:03 AM
idw's Avatar
idw idw is offline
Year: sf
Model: sf
Transmission: m
Hows the paint work hold up off road? I've tried a couple of paints but can't find anything hard wearing enugh for under the car.
I'd add some photos but you work will just put mine to shame haha! and I've not been making anything for the car lately, been doing more woodworking
  #14
Unread 21st September 2015, 08:38 AM
BenLukkie BenLukkie is offline
Year: 1999
Transmission: manual
BenLukkie is on a distinguished road
Default DIY Spare tire carrier
Soo as it's been a while since anyone posted something in here; I'll go ahead and post my DIY fabrication
As my dog is getting older, she has trouble getting in and out of the car, also bought a full size spare Grabber, so combined the two problems and made a swing down spare carrier and dog step.
The idea; Mod my oem hitch to carry a frame, make the frame fold down the wheel and use back of the frame as step for the dog..
Basic frame welded
Then was on a roll and didn take pics until done..
Closed
Open
Overcenter latch welded to rear gate, and a slideblock on the bumper to carry some load.
Now use the oem spare wheel well for some tools and stuff
Did a testrun last sunday with the 'big' boys and it held up excellently!
No pics of the dog using the step though..
  #15
Unread 15th October 2015, 02:54 PM
casperfromholland casperfromholland is offline
Year: 1999
Model: forester sf
Transmission: manual 5speed 4.44 end h/l 1.59
casperfromholland is on a distinguished road
Nice build Ben!
'99 SF 2.0n/a,+2cm front+4cm rear,kings,LPG, winch
  #16
Unread 18th October 2015, 04:03 AM
teki1975 teki1975 is offline
Year: 1998
Model: Outback
Transmission: Auto
teki1975 is on a distinguished road
Looks great will be looking to do something similar myself
  #17
Unread 10th July 2018, 01:34 PM
GETSOME GETSOME is offline
Year: 1995
Model: Legacy
Transmission: Auto
GETSOME is on a distinguished road
Default DIY front sway links and rear link solution
After a frustrating half hour at auto zone trying to explain to the kid behind the counter that I need sway bar links “about this size /shape etc” and him refusing to go open a box or two I decided to fab some up. It’s not a super integral part and if it breaks I’m not going to injure my self or others so I went the easies fastest way I could come up with. I took the bushings from an old set of fromt links , drilled upper and lower holes in some 3/8 aluminum diamond plate I had around, jammed the bushings in, goobered some indie weld in after installation to keep them from moving laterally and blammo....perfect fit front sway links after my 6” lift. This is on a 95 legacy sedan. For the rears I came up with a brilliant solution.
Stay with me here. I was laying under the car staring at the rear sway bar and lateral links trying to come up with how I was going to get the extra length I needed to connect them. Turns out all it takes is a simple swaparoo. Swap the left and right furthest rear lateral arms and the mounting points for the sway bar links are magically on top of the link instead of underneath! Re mount your original sway bar links and your all set. Throw a pin in the top of the link and now you have quick disconnect sway bars.
Boom
File Type: jpg 9B3529FA-F705-4240-B6BD-4999C384D4FB.jpg (16.7 KB, 11 views)
Tags
diy fabrication thread
