ECU Fault Codes for 99 EJ20 Forester - Help!
Dedman
Perth Western Australia
Forester
5MT
Hi all
I have an issues that I get a check engine light whenever I do a river crossing which I would like to stop. My problem is that nowhere on the net seems to have a correct CEL code list for the Australian ej20 sf forester so I have no idea where the water is getting in.
Connecting the wires under the dash I get the following codes from the check engine light:
22
26
53
54
I have not found a list that contains the 53 or 54 codes except for a carby engine which gives me no faith in its accuracy...
If anyone has a complete list that would be much appreciated or at least what these codes indicate.
Thanks
Posted on ozfoz now so hopefully I will get a reply there. Thanks
As far as I know the 00 outback is OBD2 where as the sf forester is OBD1 or something that is not OBD2. I have not found a scanner that will work with the forester...
Can't give you an idea of the codes, but I can say that petrol engines don't like water crossings..... At a bare minimum give all connections a blast of WD40 before every trip with watercrossings, or put dielectric grease in all connections.
https://offroadsubarus.com/showpost.php?p=79780&postcount=7
My outback is obd dedman. If it works for you, its only cost few bucks for the cable compare to connecting the plug and count the code everytime.
Cheers.
There's a good thread on Subaru codes somewhere but I cant find it. I think its AUSubaru, I've searched but no luck
I was under the impression that you could not hook a laptop up to my car but I will see in a few weeks when the VAGCOM cable arrives...
In terms of the engine not liking water crossings, it works fine except for the CEL no loss of power no issues that I am aware of. The CEL always comes on with moderate water though and at no other times.
The crossing that was the culprit this time
[ame="https://www.youtube.com/watch?v=qf5z3UM_h_c"]Deep crossing of Wonnangatta River on Scrubby Creek Track - YouTube[/ame]
Cable and freeSSM should work - as long as you get the VAG-com cable with the 'right' chipset.
This is the combo that works for me on my JDM non-OBD EJ208
For the codes, I have a gen3 Liberty FSM list of codes for a "EJ20SO w/o OBD", which are consistent with the '1988 and later models with Multi-Point Fuel Injection (including Legacy)' codes here: https://www.troublecodes.net/Subaru/
53 = Immobiliser faulty
54 - not listed
22 = Knock Sensor
26 = Intake temp sensor
I think intake air temp is up near the filter box, while the knock sensor is bolted to the block under the throttle body... maybe you're getting water up there or a local ground is dodgy and getting soaked. The knock sensor looks like it sits it a location that could pool water, for example.
53 is what i got when i nicked the wiring for the fuel pump.
Well I tried 3 different vag com cables and none of them could communicate with the ecu using freessm. Not sure if I still have not found the correct cable or if its just not possible with the sf forester...
I guess ill just have to try clear the fault using the plugs below the dash and drive through some water and check them again...
54 - not listed
22 = Knock Sensor
You bloody ripper your a legend mate.
