  #4921
Unread 29th May 2017, 09:22 AM
havachat's Avatar
havachat havachat is offline
Year: 2002
Model: Forester SG
Funny about that Kevin,
I have always bought the genuine brake pedal rubber too!
  #4922
Unread 22nd July 2017, 08:48 AM
havachat's Avatar
Year: 2002
Model: Forester SG
Drained the rear diff today. I struggled to undo the drain plug Is there a torque setting for the drain & fill plugs ?
Refilled with Penrite fully synth 75w-90.
Will do the gear box tomorrow.
  #4923
Unread 22nd July 2017, 11:23 AM
duncanm's Avatar
duncanm duncanm is offline
Year: 1998
Transmission: 5MT DR
'tight enough'. They're usually pretty hard to undo because they rarely get removed.
manual for the Lib/Outback strangely has two numbers for the different rear diffs, 34 and 49Nm
44Nm for both Manual trans and Auto front diff.
TT Outback
  #4924
Unread 22nd July 2017, 09:42 PM
I put Teflon tape on the diff plug now so as it's easier to remove.
MY'97 Outback RIP
  #4925
NachaLuva's Avatar
Try a 13mm square diff plug tool to undo them, makes it easy:
https://www.ebay.com.au/sch/sis.html...75.m4096.l9146
Diff plug torque setting is 36ftlb 49Nm
  #4926
Unread 23rd July 2017, 09:34 AM
havachat's Avatar
Year: 2002
Model: Forester SG
Thanks for the input.
Didn't get to the gearbox before the rain set in. One of the challenges of having to work in the open
It will take me a while to get set up too as I don't have any level ground. Just doing the diff was a challenge as I had pieces of timber under different wheels to get the car level. Even then I had to jack the front up to get it to drain fully.
The gearbox drain on the manual is also in an awkward spot in front of the exhaust Y !!
  #4927
Unread 26th July 2017, 07:23 AM
Dulagarl's Avatar
Dulagarl Dulagarl is offline
Year: 2000
Model: EZ30R Forester
Installed rear KAAZ clutch type lsd (purchased from Venom). Drives great and looking forward to trying it offered soon.
Also got new BF Goodrich 215/75 r15 all terrains. Very chunky but disappointed that the rim protector is no longer a feature.
  #4928
Unread 4th August 2017, 08:56 AM
havachat's Avatar
Year: 2002
Model: Forester SG
Decided for my big trip to get the windows tinted Picked the 2002 Foz up at Tintacar tonight and happy with the result.
Had a busy week, finally changed the gear box oil, changed the spark plugs (only 75,000 over due, whoops!!). I also needed new spark plug leads as 3 of them came apart
Then the OBD light came on, so I need a new oxygen sensor! Engine oil and filter to be done on the weekend and then start packing
  #4929
Unread 4th August 2017, 09:30 PM
^ good that it happens now rather than on the trip!
MY'97 Outback RIP
  #4930
Unread 4th August 2017, 09:49 PM
NachaLuva's Avatar
Awesome! Beast mode activated!!
Where are you getting the O2 sensor from? I need one too, plus a new exhaust
