  #4851
Unread 8th August 2016, 10:42 PM
Taroona's Avatar
Taroona Taroona is offline
Year: 2015
Model: Forester 2.5L CVT Spec Edition
Transmission: CVT and 50mm SUBIELIFTOZ
Taroona is on a distinguished road
Interesting about the oil change, because I have just had the 12,500 Km dealer service done and I thought I was imagining that the engine seemed to be smoother
Forester MY15 2.5L CVT
Special Edition 50mm lift
  #4852
Unread 8th August 2016, 10:51 PM
idw's Avatar
idw idw is offline
Year: sf
Model: sf
Transmission: m
Nar even my old motor responds to an oil change more than I expect
  #4853
Unread 9th August 2016, 06:46 PM
gregjet's Avatar
gregjet gregjet is offline
Year: 2014
Model: xv
Transmission: manual
gregjet is on a distinguished road
" Yes, it's the same on all newer subies, not sure about old school. Very bad positioning. I just cut the cable tie & moved it a little, didn't bother with a bracket for it."
That is a big bit of cable with a lot of copper. I will feel safer with a intermediate support for a free unsupported run that long.
I suspect you are right about the diff itself but I will make up a guard that also protects the exhaust run under the suspension crush point.
The original Aluminium plate I started making for the engine had a hole to access the sump plug. The distance up from the plate meant that it was gonna be protected from a hit. The Subextreme one would too, but it's too close to the support bolts to retain strength so it's back to removeing the plate to change oil ( stuff it!!!)
  #4854
Unread 14th August 2016, 10:16 PM
NachaLuva's Avatar
2 months ago, I did some stickers...
  #4855
Unread 15th August 2016, 10:16 AM
jf1sf5's Avatar
jf1sf5 jf1sf5 is offline
Cool !
We need a trip report !
Subversive...
  #4856
Unread 17th August 2016, 08:17 AM
El_Freddo's Avatar
Year: 1988
Model: EJ22'd L series
Hehehe... "did some stickers"...
Good one!
  #4857
Unread 17th August 2016, 08:55 AM
Scooby2's Avatar
Scooby2 Scooby2 is offline
Year: 2006
Model: Holden Adventra
Transmission: Auto
Scooby2 is on a distinguished road
Musta been some heavy stickers! Looks gr8 Luva of the Nacha!
Best regards
:shrug:Scooby2 00 2.5 Outback, 95 Liberty
  #4858
Unread 19th August 2016, 12:16 AM
Dedman's Avatar
Dedman Dedman is offline
Year: 1999
Transmission: 5MT
Dedman is on a distinguished road
I have done a lot of work on the forester over the last 2 weeks however today was trying to fit my entire life into one car. Forester is now all packed and ready for its 4000km journey across the country. Just slightly overloaded, who needs a lift anyway....
In preparation it has had a heap of work done to make it a little less worse for wear...
- New (used) exhaust off a EJ22 liberty
- New 215/75/R15 BFG tyres all round (which despite what most people say actually rub slightly on the front on stock offset rims)
- New tie rods and ball joints
- New massive light bar
- New front shocks
- New front wheel bearings
- New rear trailing arm front bushes
- Wheel alignment
- Full engine service
Now lets all hope it actually makes it without something falling off...
99 Foz 2.0 n/a 50mm Strut, Kings, 9000lbs Winch, Offroad Bumper, Custom Sumpguard, Snorkel
  #4859
Unread 19th August 2016, 05:55 AM
idw's Avatar
idw idw is offline
Year: sf
Model: sf
Transmission: m
Hope those bikes are locked on that thing somehow, have a good trip!
  #4860
Unread 19th August 2016, 06:09 AM
jf1sf5's Avatar
Have a nice trip
Will the front CV's hold up this angle for such a long trip
Subversive...
