Go Back   OFFROADSUBARUS.COM > Technical Forums > Bolt-On Bits, Accessories and Protection
  #11
Unread 23rd May 2018, 07:31 AM
Rally's Avatar
Rally Rally is offline
Year: 2004
It was a few years ago, so I am not sure. I think I had raised springs 25mm. Which is what I am still running now. This video was taken this year. https://m.youtube.com/watch?v=dVwNIblSTxQ. The sump guard was dented but survived.
  #12
Unread 23rd May 2018, 08:15 AM
Rally's Avatar
Year: 2004
These photos were all done when the car was totally standard. I did not get stuck and made it all the way through with only a cracked splash guard
  #13
Unread 23rd May 2018, 08:18 AM
Rally's Avatar
Year: 2004
If you can't see the photos, use Chrome and then go here https://chrome.google.com/webstore/d...alioapbifiaedg
  #14
Unread 23rd May 2018, 09:21 AM
Ben Up North's Avatar
can only hope to improve
Year: 2004 | 1992
Transmission: 5MT D/R | 4EAT
Think of how much nicer that bit would have been with a bit of extra clearance..
  #15
Unread 23rd May 2018, 09:46 AM
Red XS's Avatar
Red XS Red XS is offline
Year: 2006
Model: SG Forester XS
SubaXtreme are starting to do 6mm sheet bash plates which would be best of both sides. Bit late for those already with a bash plate, but good option for those buying.
https://www.facebook.com/Subaxtreme/...type=3&theater
  #16
Unread 23rd May 2018, 02:39 PM
Rally's Avatar
Year: 2004
The second hit was because I was going too fast. Not by much, maybe 3 kmh too fast. Had I have been going slower, I may not have hit, or at least not as hard. It’s pretty steep and very rutted. To give you an idea a whole group of real 4wd’s elected to take the parallel chicken track. I wanted to maintain momentum, you can hear me apply power just before. Next time I will go more slowly and really make that rear diff earn it’s keep.
But it shows just where you can go with a very mild lift and good diffs.
  #17
Unread 23rd May 2018, 07:05 PM
NachaLuva's Avatar
Exactly.
The hit at 0.13 was purely approach angle. Doesn't matter how fast or slow you're going, only way to avoid that is with more lift.
The 2nd hit at 0.17 was a big one with damage to the sump guard (not sure about the radiator support panel, that is probably bent too from a hard hit like that). Going slower would just make the hit not as hard but it would still be a hard hit. But then you start putting the entire driveline under more load, leading to failures in the tailshaft, gearbox, or clutch (hopefully clutch first). Or you can simply lift it.
It's a compromise. This is a tough climb but I've done similar with a completely stock driveline with no hits & no damage simply because I had the appropriate lift & tyres & sump guard. This is on the way back down
  #18
Unread 23rd May 2018, 07:31 PM
Rally's Avatar
Year: 2004
For god sake Mat you could not possibly say you have done similar when the video flattens everything out. Those who were there and later saw the video commented on their disappointment that the video flattens it out so much and failed so much to depict the track. I agree that a bigger lift would have meant no contact the first time and a softer hit at the second . How much softer we cannot be sure. But I could certainly have gone slower by taking advantage of the diff locker you don’t like to tell others about and the torque of the engine. I will be putting this to the test next month. I am still undecided about putting a lift kit in the car. I think I will although maybe later in the year. Damage was limited to a bent sump guard. That’s what it is there for. Even if I put a lift kit in the same thing can still happen on a different track. The point is you can still go lots of places at or close to standard height
  #19
Unread 24th May 2018, 04:55 AM
Year: 2004 | 1992
Absolutely! If I could put decent diffs in at around the same price I paid for the lift I'd be one happy chappy.
Unfortunately, I reckon your diff setup is way out of reach for me.
Unless i win a lottery. Which is made marginally less possible by the fact that I don't enter them. Given the difference in odds of winning between buying or not buying a lottery ticked, I reckon I'm currently well in front.
  #20
Unread 24th May 2018, 05:19 AM
Rally's Avatar
Year: 2004
Ok, but look at the still photos I posted above. Standard ride height, standard diffs
