Go Back   OFFROADSUBARUS.COM > Technical Forums > Electrical and Lighting
  #21
Unread 7th April 2018, 12:46 AM
Ben Up North's Avatar
can only hope to improve
Year: 2004 | 1992
Transmission: 5MT D/R | 4EAT
Originally Posted by Kevin View Post
Where are you getting your positive?
If you are tapping low beam then you are tapping neg as there is just one pos wire at each headlight and 2 negs one each for hi and low beam (which are switched).
I know, right?!
Not sure what's going on.
  • Using a Lightforce loom, which gives you the ability to remove a lead that goes to earth (when positively switched) and loop it back into the relay for negatively switched vehicles.
  • I originally tapped the high beam and did the loop back thing. spotlights came on on high beam and when lights were turned off. I've got an overide switch in the cabin that could turn them off completely, so it wasn't terrible, but not good.
  • I then changed the loom setup so that it was for a positively switched vehicle. Spotlights came on on low beam only, but were off when lights were off.
  • so then I had a mad idea, and tapped the low beam wire and left the loom setup for positive switched vehicle. It works exactly as a bought one!
Does any of that make sense? it doesn't really to me...
  #22
Unread 7th April 2018, 01:46 AM
What's connected at each relay pin i.e.
30
85
86
87
MY'97 Outback RIP
  #23
Unread 7th April 2018, 03:43 AM
Year: 2004 | 1992
How about some pictures, because I like pictures..!
relay:
The wires going into it:
Black at top goes to lights.
Yellow at bottom goes to +ive on battery
Yellow Black on left goes to earth (you can see the "-ive switched" cable too, with the white tape around it)
Red Black goes to cabin switch.
Not visible: tapped wire which goes from low beam to cabin switch. Well, it's tapped to low beam according to this:
Lightforce instructions here
What I've done really shouldn't be working. Should it?
  #24
Unread 7th April 2018, 03:45 AM
Year: 2004 | 1992
Oh, the cable(s) to the lights are on a flat connector, the the others all vertical if that helps figure out what's going where??
  #25
Unread 7th April 2018, 04:23 AM
Pictures may be worth a thousand words.....but not those!
I can't tell which pin has which wire connected to it. I think the relay wiring has something to do with it working the way it is - I know there is a setup called "combination" (of pos and neg) and perhaps you've stumbled upon it
MY'97 Outback RIP
  #26
Unread 6th July 2018, 08:59 AM
1WD Foz 1WD Foz is offline
Year: 1998
Model: Forester with a EJ22
Transmission: Manual 5 speed
Originally Posted by Ben Up North View Post
I should take some pics now it's all done. Might do that tonight..
always wanted to use that emoji
more pics of the lights you have on the car plz
1WD
  #27
Unread 6th July 2018, 11:11 AM
Year: 2004 | 1992
I must. To be honest, when I'm driving at night where I'm using my spotties, the last thing I want to do is stop.
I haven't taken any yet.
There's a couple of pics in the journal of them on the car, but that's about it.
Nothings melted yet though.
