Go Back   OFFROADSUBARUS.COM > Trading Post > Wanted
  #1
Unread 20th November 2017, 04:26 AM
skep skep is offline
Year: 2003
Model: Forester xs
Transmission: Manual
skep is on a distinguished road
Default GOT - SG transfer case output shaft/bearing
HI! I am in the middle of a gearbox build and found my viscous cir-clip has smashed a couple of teeth off the (shorter) transfer output shaft so I am after a replacement one and bearing(cant wait for a replacement 20kg though)... alldrive only sell them in sets so I thought I would see if anyone had one to part with on here first.. Also needing a front bearing on the transfer driven gear as well but most likely get from all-drive. cheers
  #2
Unread 20th November 2017, 06:55 AM
duncanm's Avatar
duncanm duncanm is offline
Year: 1998
Transmission: 5MT DR
try partsouq. Cheap, shipped in a couple of days.
Bearings are generic - just go to your local reputable bearing supplier for a replacement (NSK, etc)
TT Outback
  #3
Unread 21st November 2017, 04:21 AM
Year: 2003
Model: Forester xs
ok thanks for the reply bud...
  #4
Unread 21st November 2017, 05:50 PM
jf1sf5's Avatar
jf1sf5 jf1sf5 is offline
SF's with EJ20J have a more solid viscous transfer case than later Foresters. But you need to swap the entire housing.
Subversive...
  #5
Unread 24th November 2017, 05:01 AM
Year: 2003
Model: Forester xs
ah ok,, I ended up getting a used box (same model) for a good price so hopefully the goods are... good!
