  #11
Unread 9th June 2017, 03:16 AM
Year: 2013 / 2008
Transmission: 5EAT
The Subaru eye bolt does not have sharp edges.
And 2/3 of 32,000lb, which is what mine are rated for, is still plenty enough anyway.
Also, these are made for use on heavy vehicles, not just for light ones. They vary in capacity just as metal shackles do.
18 4R TRDOP, 08 Tribeca
(13H6OB 2" SLOz, 06 B9)
  #12
Unread 9th June 2017, 07:15 AM
duncanm's Avatar
duncanm duncanm is offline
Year: 1998
Transmission: 5MT DR
yeh - I do get all of that. Sharp edges are easy to inspect/address/protect and damage can be inspected for.. but the published load ratings worry me.
32,000lb isn't really that much. use a minimum 3:1 safety factor and you're now down to 5T SWL. About right.
The other one I linked to above has a breaking strength of 9T -- so only 3T or less SWL with a decent safety factor - and that's brand new.
You're right in that you don't have a real concern for Subarus - given their relatively light weight, and I would have little concern using shackles I made myself with regular inspection; if you have any worry, then just up-size to 8mm dyneema.
My real concern is with the somewhat misleading published breaking loads (and therefore SWL) when used with inappropriately radiused recovery points. It just isn't mentioned on any of the manufacturers' websites. That seems like a very large oversight.
Inspection is a problem too. Its easy to check for chafe - as that's on the outside. If you have a chafe cover, then you can't see any damage to the core as you would get in the outer-most fibres when using a small radius, unless you pull the chafe cover back. There is no mention of that on any users guides, either.
The bubba shackles have no chafe guard -- so there's no problems with inspection, but you have more risk of abrasion and cut damage.
Compare that with load-rated shackles -- and its a commercial liability minefield, IMHO.
I cannot find any use and inspection guides on the commercially available shackles, other than generic 'inspect for wear' warnings.
TT Outback
  #13
Unread 9th June 2017, 02:58 PM
Year: 2013 / 2008
Transmission: 5EAT
Bubba rope is not a basement operation so I highly doubt that there are any issues with their ratings; on the contrary, I would expect their ropes to do better than the publicized numbers.
I am no engineer, but it seems to me that while it is true that metal shackles have high safety factors, this is because the good shackles are made for overhead lifting operations with tremendous liability potential and continuous, commercial use over prolonged periods of time. In the case of off-road recovery, the high safety factor of metal shackles is much more needed as a precaution for obvious reasons.
Finally, your snatch strap will break first anyway. After all, you are only using 12,000 lb straps in Australia so I do not see how a 32,000lb shackle will break first.
That's before accounting for potentially the weakest spot, the eye bolt. Subaru does not publish the eye bolt's specs and I have used it once successfully in a brutal, hard pull of the Tribeca where it bent but did not break, but from looking at whatever info I could find on the internet, I have a hard time believing that its 1/4 inch eye can match the strength of the bubba rope shackle.
Thus though I lack the expertise to make a provable claim, I consider the eye bolt the weakest spot and I am thus personally convinced that the bubba rope is much safer for Subaru use than a traditional shackle. I have the latter only for use with my hitch recovery insert, in which case it is also possible to spread the load between the rear eye bolt and the recovery insert.
  #14
Unread 9th June 2017, 09:44 PM
duncanm's Avatar
Year: 1998
MAS -- maybe my language is being too harsh -- I actually agree that they're a much preferred solution for Subarus... and agree that the weakest point is probably the anchor point.
I also have no doubt they meet their published breaking strengths -- its actually pretty hard to make a soft shackle that doesn't meet approximately the line strength.
My real beef is with the apparent lassez-faire attitude to use & care instructions of the companies selling them.
TT Outback
