Go Back   OFFROADSUBARUS.COM > Technical Forums > Electrical and Lighting
  #11
Unread 2nd May 2017, 12:11 AM
turbo1600 turbo1600 is offline
Year: 1998
Model: outback
Transmission: auto
turbo1600 is on a distinguished road
Originally Posted by duncanm View Post
Ah ok - there are two sensors.
Single wire for the gauge, 3-wire for the ECU (the brown socket)
The wiring diagram I have (which is 1998+ AUDM BE/BH. But you say 1998 DOHC, which makes me suspect you've got a late BG), says plug E8 is triangular, light grey.
Pins 1-2-3 clockwise from top left. Point of triangle down.
1 - BY
2 - WG
3 - BR
Crank sensor is Yellow (pin 1) and Orange.
Cam sensor is Black (pin 1) and White -- sure you're not confusing the two?
Dunno if any of that helps..
hi, as stated before its a TWO wire coolant sensor .: see here : http://www.ebay.com.au/itm/Coolant-T...UAAOSwx2dYEdos
  #12
Unread 2nd May 2017, 12:17 AM
duncanm's Avatar
duncanm duncanm is offline
Year: 1998
Transmission: 5MT DR
which is why I said 'dunno if this helps'.
Do you have a late-model BG?
either way - find yourself a wiring diagram, or try googling. Lots of images of coolant sensors.
As noted above, its most likely just a thermistor and doesn't care which way its wired.
TT Outback
