  #11
Unread 21st August 2016, 09:43 PM
NachaLuva's Avatar
I agree, 2T is too light for any component int snatching. The lightest I like using is a 3.2T bow shackle which as MAS mentioned has a high safety factor. I use a 5T equaliser strap, but as it is often used near things like bumpers where the strain can be localised, using a 8T would not be overkill.
It's really only the snatch strap itself, where stretch is reduced as you go bigger, that 5T would be the maximum
  #12
Unread 22nd August 2016, 03:40 AM
Taroona's Avatar
Taroona Taroona is offline
Year: 2015
Model: Forester 2.5L CVT Spec Edition
Transmission: CVT and 50mm SUBIELIFTOZ
Taroona is on a distinguished road
@NachaLuva
Would this do for an equaliser strap? Only $20 plus some shackles
https://www.bunnings.com.au/grunt-50...strap_p4310409
Forester MY15 2.5L CVT
Special Edition 50mm lift
  #13
Unread 22nd August 2016, 05:31 AM
NachaLuva's Avatar
It's 4.5T breaking strain with 2.2T SWL, about the same as my snatch strap & winch extension strap so it should be ok.
When using it, thread the equaliser strap through the snatch strap loop, never use a shackle to join straps. Make sure your bow shackles are good quality rated with the rating stamped on the side.
Vert, I was wrong about your strap, I was thinking it was 2T breaking strain, 2T SWL is fine
  #14
Unread 23rd August 2016, 01:19 AM
idw's Avatar
idw idw is offline
Year: sf
Model: sf
Transmission: m
http://www.ebay.com.au/itm/Straps2go...-/291837099435
can't recommend that kit more!
-2 3.2 shackles
-equaliser strap
-5.4 ton snatch
-bag
-****ty gloves you might use once to work out how ****ty they are...
Given mine a real punishment over the last few years. Company is owned by JustStraps
EDIT: Even the aussie made kit by them is a great price http://www.ebay.com.au/itm/Just-Stra...37099435&rt=nc
Both the same kit, straps2go webbing is made in china
