Go Back   OFFROADSUBARUS.COM > Technical Forums > Bolt-On Bits, Accessories and Protection
  #41
Unread 22nd May 2016, 04:22 PM
gregjet's Avatar
gregjet gregjet is offline
Year: 2014
Model: xv
Transmission: manual
gregjet is on a distinguished road
You belted it and it didn't shatter? That is interesting. As far as I know the trick with Al casting it to slow cool them. If they form bigger crystals and/or if they have a higher copper content, they tend to bend rather than break immediately. Adding scandium also works brilliantly, but getting a copper/scandium doped cast aluminium might be a little hopeful I fear.
I have just discovered a fibre that has been around for a while called innegra that I didn't know about. Very light and VERY tough in composites. I was looking for a kevlar supplier to make skid plated for the transmission and diffs when I found it. If I can find a supplier for both I think I will have a go at using them to make the aforementioned. If that works I will try a engine bash plate. Innegra is way cheaper than kevlar and carbon.
  #42
Unread 29th May 2016, 12:04 AM
Vert Vert is offline
Year: 2007
Model: Forester x
Transmission: Auto
Vert is on a distinguished road
Originally Posted by Taroona View Post
Who has one of these fitted to their Forester? and how much ground clearance did you loose?
Mate fitted my xtreme one up on a 07 for forester. At front flat bolt up part was about 330mm to ground at lowest base of it was about 230mm .
Also note doing this on a non level driveway so results could vary.
Hope that helps.
  #43
Unread 25th October 2017, 07:34 AM
Ben Up North's Avatar
can only hope to improve
Year: 2004 | 1992
Transmission: 5MT D/R | 4EAT
Hi gregjet, did you have any joy with the Innegra?
Cheers,
Ben
  #44
Unread 25th October 2017, 08:17 AM
duncanm's Avatar
duncanm duncanm is offline
Year: 1998
Transmission: 5MT DR
http://www.shapers.com.au/2oz-innegr...oard-cloth-30/
TT Outback
