Go Back   OFFROADSUBARUS.COM > Trading Post > Group Buys
  #21
Unread 23rd August 2014, 03:07 PM
stilson's Avatar
stilson stilson is offline
stilson is on a distinguished road
Are their 1.44 different/better than the SF DR set?
The Grey Fox - MY08 SG XT Luxury
  #22
Unread 23rd August 2014, 03:17 PM
catchya catchya is offline
Year: 2005
Model: Forester XT
Transmission: Manual
catchya is on a distinguished road
They are billet products, not cast. He assured me that their gear sets would handle the 333nm of input torque my motor produces.
  #23
Unread 24th August 2014, 12:35 AM
NachaLuva's Avatar
Stilson, I would stick with OEM 1.447 LR unless you want to go to 1.59. Then the ADS one will fit in with a 4.111 crown wheel with NO mods or the 4.44 with minor machining. It will also be stronger as Catchya said.
For Catchya, you might benefit from the stronger LR with your increased torque. Just remember, its still vulnerable so change into HR whenever you can & don't dump power through it.
I'm not sure the OEM gears are cast, pretty sure they're machined just not as high a grade of steel as ADS uses
  #24
Unread 24th August 2014, 09:01 AM
kiwifoz's Avatar
kiwifoz kiwifoz is offline
Year: 1997
Model: Nissan Terrano
Transmission: 4sp auto, ATTESA PT4WD, D/R
kiwifoz is on a distinguished road
I doubt they would cast the gears, seems like a bad idea given the entire power of the vehicle is transferred through them and Subaru intended them to be mainly used for towing...
Would ADS sell the 4.44 rings pre-machined? I'd love to go DCCD, long 5th, 4.44, helical front LSD and 1.59:1 but if they can't do a pre-machined I won't go 4.44 as it'll cost too much to get it done here.
Also, I was reading something on SF.org about using an L-series 5th gear as it's longer than the Forester's, is this possible? If so, then I could just buy an L-series DR gearbox, STi RA DCCD 4.44 LSD box and modify them both into my SG box and have everything I want (apart from the ARB locking R180 rear)...
RIP 2002 Forester, 2009 GV
1997 Nissan Terrano
  #25
Unread 24th August 2014, 09:46 AM
pezimm's Avatar
pezimm pezimm is offline
pezimm is on a distinguished road
Blanks are forged than teeth are milled... No casting...
A forging would be stronger than a billet piece, since the internal material tensions are all aligned in a way to reinforce the part.
Lifted Forester XT Auto - MY07
  #26
Unread 24th August 2014, 10:01 AM
Year: 2005
Model: Forester XT
Hi NL
Cheers for the reminder mate. Both ADS L/R gearsets would suffice for my applications.
If I was to use the stock SF/SG L/R gearsets, something will break as my engine produces roughly the same torque @2400rpms than a H6 EZ30 motors produces at peak.
  #27
Unread 24th August 2014, 05:59 PM
Dedman's Avatar
Dedman Dedman is offline
Year: 1999
Transmission: 5MT
Dedman is on a distinguished road
Something for everyone to consider. It is very very unlikely that you will break your low range gears or anything to do with the low range section regardless if its a OEM or ADS set. This is especially true for the better low range ratios. The reason for this is that subaru low range is on the input to the gearbox meaning it multiplies the power on every other component including your 1-5 gears. I cant say anything for other boxes but for the SF box this means that even with stock low range 1st gear and reverse will always break before the low range does.
99 Foz 2.0 n/a 50mm Strut, Kings, 9000lbs Winch, Offroad Bumper, Custom Sumpguard, Snorkel
  #28
Unread 24th August 2014, 06:02 PM
Dedman's Avatar
Year: 1999
Transmission: 5MT
SG 5th is .780 in AUS
L series is 0.870 for the part time box and is not compatible.
I think it might be an RX liberty or something like that which had a .721 5th that should work
You need to keep in mind how big the 4th-5th ratio gap is getting though...
  #29
Unread 24th August 2014, 10:15 PM
twowings's Avatar
twowings twowings is offline
Year: 2013
Transmission: 5-speed MT
twowings is on a distinguished road
I have a 2013 SH with a 5MT....I had emailed him several months back and he said no problem in supplying a D/R 5-speed with a low 1st...I'm guessing I could get the group buy price and then handle shipping costs to the U.S. separately...keep us posted!
There's someone in my head but it's not me...
  #30
Unread 25th August 2014, 03:55 AM
NachaLuva's Avatar
Bad news, ADS are going to look for a new supplier after all their issues so no LRs will be available for at least several months
They still have other components but it looks like I wont be pursuing a group buy anymore. I'm happy for someelse to take over if they want.
kiwifoz, yes they do sell the 4.44s already machined. New $600 machined, reco $400 machined
