Go Back   OFFROADSUBARUS.COM > Reviews > Products
  #11
Unread 2nd June 2014, 11:28 PM
admin admin is offline
admin has disabled reputation
Hi RB - how much does it weigh and what dimensions for stowage?
PS - it's Kevin BTW
  #12
Unread 2nd June 2014, 11:58 PM
Ratbag's Avatar
Ratbag Ratbag is offline
Year: MY06, MY10
Model: Forester SG & SH
Gidday Kevin
I guessed that ... .
It's about 550 x 250 x 350 mms, and weighs 4.4 Kgs in its carry bag. That's without squashing it. I don't want to do the latter ATM, as it has a very sharp ended band clamp around the exhaust pipe fitting funnel. This needs to be properly bound up so that it doesn't chafe or puncture the bag in transit. Seems to be the single part that's not really up to what appears otherwise to be a good quality product.
The tube from the exhaust pipe appears to be made of some kind of high temperature material. This is about 6m+ long.
Folded up properly, the air bag by itself is about 370 x 270 x 130 mms.
The carry bag is a very loose fit, even with everything in it. Not one of those that you need a factory machine to re-insert it once it has been removed and used ... . Of course, the zipper is the weakest part of it.
If it weren't raining and cold here - and if I felt somewhat less like warmed over dog vomit - I would be giving it a test run today.
The bearing area is such that it would appear to take some rough usage to puncture it, just IMHO. It seems to be quite strongly made. Only time will tell with this, of course.
  #13
Unread 3rd June 2014, 07:00 AM
Thanks RB (I forgot I was in "admin" mode when I posted the question)
MY'97 Outback RIP
  #14
Unread 4th October 2014, 02:42 AM
Ratbag's Avatar
Year: MY06, MY10
Gidday Folks
Some photos of using the bull bag to lift my trailer off its springs.
This thing is amazingly stable! Having a big footprint at each end helps, I guess, but it really is amazingly stable ...
It's like lifting the back of the trailer up onto a table!
It inflates very quickly using my compressor. I didn't try the exhaust inflation. Deflates as slowly or as fast as one wants it to. Is very easy to deploy (but watch out for sharp bits and hot bits at either end). I did not use the felt pads that come with it, as the trailer bottom is quite flat (unlike most cars) and it was in the driveway, so a flat, even ground surface as well.
  #15
Unread 25th November 2014, 04:50 AM
kiwifoz's Avatar
kiwifoz kiwifoz is offline
Year: 1997
Model: Nissan Terrano
Transmission: 4sp auto, ATTESA PT4WD, D/R
kiwifoz is on a distinguished road
Certainly looks the part! I've heard mixed reviews of these, people have had them explode under Land Bruisers and the like - but for a light Subaru they seem like an easier and safer alternative to a high-lift jack, so long as you avoid the aforementioned hot/pointy bits.
Speaking of jacks, about a month ago I had an interesting experience... Was hunting with Dad in his Pathie, and we slit the sidewall of the GT radial H/T tyre. Didin't notice it was flat until a few kms down the road and we kept dragging over small humps... So up went the jack, swapped on the spare and kept going.
About 10kms later, still offroad, there was a bit of a nasty crunch and the truck stopped dead, back left corner on the ground... Yes, my genius father had forgotten to tighten the lugnuts and the wheel fell off. Luckily, all the lugnuts had come off within a metre of them all and we found them all. Unfortunately, the centre of the wheel (alloy 17") had been damaged and two of the steel washer things had popped out! They didn't want to go back in either... As well, the edge of the left rear panel was folded in and the previously damaged bumper skin was again half off (hit it crossing a creek in reverse last August)
So, we cranked out the jack and got to work. HOWEVER. About halfway up, the jack seized. Just stopped jacking. It was just one of those crap scissor-type ones and it had clearly had enough as the thread stripped. So in order to refit the now-damaged spare, we had to dig a sizeable hole in the road. Which was complicated by the rock-hard baked Central Otago dirt. Luckily the stakes for the hand winch (no trees in Central to winch from) proved good for breaking ground before shovelling. Took 30min to dig a big enough hole to fit the wheel in. Bolted it on with 4 nuts not 6 and drove out.
Was a slow and careful trip back out after that... Didn't want another puncture.
TL/DR - do up your lugnuts and tighten them when you drop it off the jack!
There's now a hydraulic bottle jack in the car. Like the one supplied from the factory with our old R50 JDM Terrano.
RIP 2002 Forester, 2009 GV
1997 Nissan Terrano
Last edited by kiwifoz; 25th November 2014 at 05:01 AM. Reason: A long-winded tale of woe...
  #16
Unread 25th November 2014, 05:28 AM
Ratbag's Avatar
Year: MY06, MY10
^ Extremely highly recommended by the West Oz Police Force in their handbook "Aids to Survival", and far less dangerous than any kind of wallaby jack (high lift mechanical jack).
I have used the latter, but one needs to be very careful - they remove fingers faster than any surgeon can, will break wrists, arms or any other parts within reach, will fail catastrophically if not used correctly with every stroke ... etc, etc.
My bull bag is designed and made in Oz, and has a rated capacity of 4 tonnes GVM. Unless one is stupid or careless enough to place it wrongly, this will easily support a fully loaded Land Bruiser balanced on it ... .
I could rock my trailer fairly violently from side to side with it sitting on this thing (I was also a tad skeptical ... ) and the front jockey wheel. The trailer would barely move sideways at all, in spite of my efforts. It was like having it sitting on a big strong table!
  #17
Unread 25th November 2014, 05:35 AM
kiwifoz's Avatar
Year: 1997
Sweet, sounds pretty ideal then! I must say they look pretty comical though, like one of those inflatable 'feet seat' footstools or whatever they are.
The other problem with a high-lift is you need proper, reinforced points to lift from.
1997 Nissan Terrano
Last edited by kiwifoz; 25th November 2014 at 05:36 AM. Reason: Unintentional innuendo
  #18
Unread 13th August 2016, 04:18 AM
Year: 2013 / 2008
Transmission: 5EAT
I have said this elsewhere but came across this thread by chance so will repeat here.
Air jacks also need proper support points or rather space. Good luck using one in the rear, especially with dual exhaust. Maybe with a hitch, depending on style and mounting.
In the front it works well WITH skid plates. But even just using it to replace a rear tire on a trail would be quite painful. But, hey, it is great for trailer tires!
18 4R TRDOP, 08 Tribeca
(13H6OB 2" SLOz, 06 B9)
Tags
air jack, air lift jack, bull bag, exhaust jack
