Go Back   OFFROADSUBARUS.COM > Reviews > Products
  #21
Unread 14th December 2013, 06:36 PM
idw's Avatar
idw idw is offline
Year: sf
Model: sf
Transmission: m
Probably about 10 minutes from pulling it out of the boot to packing it up, i usually inflate from 18-38psi 205/75/15.
  #22
Unread 14th December 2013, 07:35 PM
Athos's Avatar
Athos Athos is offline
Athos is on a distinguished road
So that's 18->38 across 4 tyres? Which compressor? "SCA Air Devil"?
MY13 Forester 2.5i. Previously MY03 & MY06 X's.
  #23
Unread 14th December 2013, 08:29 PM
subyroo's Avatar
subyroo subyroo is offline
Senior Member
subyroo is on a distinguished road
This one looks good too, currently on special for $200.00 and comes with 5yr Warranty so the extra $50 could be worth it.
TJM Compressor.
Peter
2016 Honda CR-V
  #24
Unread 14th December 2013, 09:03 PM
Ratbag's Avatar
Ratbag Ratbag is offline
Year: MY06, MY10
Model: Forester SG & SH
Gidday Folks
I originally got this from Princess Trading -
http://offroadsubarus.com/showpost.p...3&postcount=20
(Lots of photos here)
It lasted about 6 tyres, blew fuses, and ultimately the power switch shat itself. The main switch is the same as the one in a PC power supply, rated at 6 amps/240V. I replaced it with an old PC PS switch, and gave it to a friend.
Princess Trading came to an amicable agreement (eventually ... ), supplying me with the heavier duty model at a price that was fair to us both. They didn't want the other one back, so I repaired it.
The twin cylinder one they sent me was assembled extremely poorly. So much so that one of the cylinders wasn't seated by around 1/8th inch, and the cylinder head was cactus in the same way.
They were most apologetic, and sent me a replacement as soon as they got my photos. Again, they didn't want the old one back ...
The full tale of this saga is here:
http://offroadsubarus.com/showthread.php?t=4578
(Lots of photos here too)
So, the replacement twin cylinder one went into the original carry box (it's just superb!), and I then pulled the other 2 cylinder one apart and repaired it ... .
I now have 2x two cylinder ones. They both work perfectly (to date), and the power switch is a 10A/240V, and a heavier duty type of switch, so should be relatively better.
  #25
Unread 14th December 2013, 09:08 PM
NachaLuva's Avatar
That TJM looks good, esp with 5yr warranty. Its not as fast (72LPM) as some others but reliability is the most important aspect of a compressor out bush IMO.
Mine is a Kinchrome (72LPM), not sure bout its warranty, but I'm happy with it. Takes bout 10min from taking out to putting away for 4 tyres 16-36PSI. $150 from ebay posted
Kinchrome 12V 72lpm 150PSI
  #26
Unread 15th December 2013, 10:29 PM
idw's Avatar
idw idw is offline
Year: sf
Model: sf
Transmission: m
yep all 4, I just looked at the SCA site and they don't list the one i have anymore. It's about 5 years old now never had any problems though, can't say anything about the newer ones, could be good could be crap. Mine looks almost exactly the same as Nachaluva's
Branded models have better support if you can afford them, but price doesn't always = quality, but on the other hand there's al ot of Chinese imports that look the same as branded models like tjm, or projector. While these ones are most likely build from the same plan and spec's in different factories, the branded one's will usually have higher QC standards. But you also have what i call the "4WD Action" mark up on some brands to consider.
  #27
Unread 16th December 2013, 02:23 AM
subyroo's Avatar
Senior Member
The TJM compressor is also 72LPM (listed under features) but as the pressure in the tyre builds the LPM drops and it would be same for any compressor I would think.
Have a look at the LPM specs in the bottom RH corner of the link in my post above to see how pressure affects the LPM flow.
Peter
2016 Honda CR-V
  #28
Unread 19th December 2013, 10:23 AM
stilson's Avatar
stilson stilson is offline
stilson is on a distinguished road
My 150L princess trading compressor died after airing up a mates 35" tyres, started making a noise when hot. Princess paid return shipping but despite a recipted delivery claimed they had not received the faulty item and it was not until I "advised them to settle the matter promptly" that my replacement was sent.
Replacement works well so far.
The Grey Fox - MY08 SG XT Luxury
  #29
Unread 2nd December 2018, 05:58 AM
Mathew Mathew is offline
Year: 2004
Transmission: Auto
Mathew is on a distinguished road
Hi Everyone,
Thought I would dig up this old thread (since I could not find anything similar) to see what everyone is using 5 years later!
Went to a few shops this weekend to have a look around. Looking for something that is not too heavy and bulky, as I don't want it taking up too much space.
Would a compressor running 72lpm (like a projecta) be OK?
  #30
Unread 2nd December 2018, 11:50 PM
Still using my ViAir based Bushranger pump; very reliable and I can highly recommend them:
https://www.ebay.com.au/itm/BUSHRANG...D/321373798972
MY'97 Outback RIP
Tags
air compressor, inflator
