Go Back   OFFROADSUBARUS.COM > Reviews > Products
  #21
Unread 11th December 2008, 01:52 AM
spinners's Avatar
spinners spinners is offline
Moderator
spinners is on a distinguished road
I recently replaced my front wiper blades as they were starting to perish.
I went with the Bosch Aerotwin single blades. WOW...
I got them from Super Cheap Auto. The part numbers BBA4 and BBA5.
They were $26 each. Not cheap, I know, but far out they look sweet on and work a treat. I now get a streak free clean window every time.
I guess time will tell how long they last and how long the stick to the window for.
Anyway. I'm happy.
Regards,
Carlo
"Improvise, Adapt & Overcome"
  #22
Unread 11th December 2008, 02:56 AM
mr turbo's Avatar
mr turbo mr turbo is offline
Year: MY05
Model: Forry XT
Transmission: manual
I bought the same ones about 2 months ago (Bosch Aerotwin single blades) from Super Cheap Auto also.
A little pricey, yes, but all I can say is that they are absolutely brilliant
They hug the window beautifully & are also whisper quiet
So when it comes time to replace them I will most definitely be buying them again
  #23
Unread 11th December 2008, 03:49 AM
subyroo's Avatar
subyroo subyroo is offline
Senior Member
subyroo is on a distinguished road
I replaced the wiper blades on my forester last week with the metal backs (2 x metal bars) and the set before them were the same, the only reason I replaced them was because they had perished over time, can't remember when I last put them on.
Good to read about the Aero's though, I'll give them a run next time.
Peter
2016 Honda CR-V
  #24
Unread 11th December 2008, 05:27 PM
apsilon's Avatar
apsilon apsilon is offline
Senior Member
apsilon is on a distinguished road
Did you have to cut them down? I was going to replace mine last weekend and decided to try these aerotwins but the 2 Supercheaps I visited didn't have the part numbers listed in the book. BBA475 and BBA530 IIRC. They had the 475 but not the 530, only 550. I assume the number is the length but wasn't sure if this design could be cut down.
  #25
Unread 12th December 2008, 01:05 AM
mr turbo's Avatar
Year: MY05
Model: Forry XT
Originally Posted by apsilon View Post
Did you have to cut them down? They had the 475 but not the 530, only 550. I assume the number is the length but wasn't sure if this design could be cut down.
No I didn't have to cut them. And yes I'm 99% sure that the number (ie 530 etc) is the length of the rubber blade.
  #26
Unread 12th December 2008, 01:28 AM
apsilon's Avatar
Senior Member
Thanks. If I'm out on the weekend I'll grab the longer 550 then.
  #27
Unread 30th October 2013, 01:30 PM
PigSti PigSti is offline
on sabbatical
Exclamation New link to Bosch AUS Wiper Blades..
New links to Bosch AUS Wiper Blades..
http://au.bosch-automotive.com/parts...ers_1/wipers_1
http://au.bosch-automotive.com/parts...wiper_blades_1
  #28
Unread 30th October 2013, 08:54 PM
obsessed's Avatar
obsessed obsessed is offline
obsessed is on a distinguished road
Another vote for the '09 or SH model Foz blades and assembly.
Not a bad price from Subaru and a bazillion times better than anything else I've used
  #29
Unread 30th October 2013, 09:10 PM
Ratbag's Avatar
Ratbag Ratbag is offline
Year: MY06, MY10
Model: Forester SG & SH
^ the last few posts ...
IME, the single most important part of a wiper blade is the suspensory ligament at the top of the blade itself, where it joins the backing part of the blade.
The OEM blades have a very soft, fine suspensory ligament. When I first got Roo1 (in early 1994), these would break at this point after only 12-15 months. Later on in Roo1's life, the OEM blades would last for 3+ years, which was acceptable to me. They still had the very fine ligament.
If this ligament is too stiff, the blades will (unfortunately ... ) last almost indefinitely, but they won't flip over and change their attack angle to the windscreen easily. This happens particularly in cross winds, but also at anything over about 90 km/h. It is this failure to "rotate" longitudinally that causes the juddering across the windscreen.
After discovering this, I never used anything but the OEM blades on Roo1 again.
Ross fitted Bosch blades to the Camry, and they were fine on that car.
IMNSHO, cheap wiper blades are worth what you pay for them ... .
  #30
Unread 30th October 2013, 09:41 PM
on sabbatical
Talking
I got the $12 (a pair) cheap ones! Can't tell the difference from the Bosch ones and have lasted 2 years now. Got to get 4 sets of the cheapies to equal the price of one of the Bosch set. Oh well perhaps in another 6 years I might upgrade!
Aero Wiper blades real Cheap / AU $12.63
