Go Back   OFFROADSUBARUS.COM > Reviews > Products
  #1
Unread 10th July 2008, 10:58 PM
Eastie Eastie is offline
Eastie is on a distinguished road
Post Replacement wipers - bosch aerotwins
Ever since new we've had problems with wiper blades on the forester and have gone through about 5 different sets in 3.5 years trying to find something that works and isn't annoying . The ones with two metal edge strips never gripped the rubber and the rubber has always worked it's way out and hit the edge of the windscreen after a couple of uses, the ones with integrated plastic frame/rubber were never the correct length and always shuddered.....
Earlier this week I took the OE brackets off the wiper arms and replaced them with bosch aerotwins, and after testing in the rain over the past few days I finaly have a set of wipers that work with rubber that won't dislodge.
http://www.bosch.com.au/content/lang...l/715_5934.htm
I picked them up from supercheap for about $23ea and they fit perfectly. Time will be the test, but straight up they are 10x better than OE and everything else I've tried.
  #2
Unread 11th July 2008, 10:18 AM
Rally's Avatar
Rally Rally is offline
Year: 2004
I found genuine ones the only ones that worked for me, but not tried these
  #3
Unread 11th July 2008, 10:25 AM
Brendon Brendon is offline
Brendon is on a distinguished road
I agree with Rally, can't beat the genuine one's
  #4
Unread 11th July 2008, 10:31 AM
eden's Avatar
eden eden is offline
bush bash'n ranga
eden is on a distinguished road
how much were they? iv'e used these silicoln ones from supacheap auto. they only last about 5-6 months but while they last they work a treat. probably the best i've used. i think there a Aunger brand. $10 a pair
cheers, Eden
2000 outback, subX bullbar + sumpguard,50mm raised strut blocks,30mm raised springs,215/65/16 rubber,uhf, dual battery system,150W spots,touchscreen navigation with oziexplorer. more to come
  #5
Unread 11th July 2008, 11:42 AM
mr turbo's Avatar
mr turbo mr turbo is offline
Year: MY05
Model: Forry XT
Transmission: manual
Mine are on their last legs & are due to be replaced, so I might have to grab a set & see how the go.
  #6
Unread 11th July 2008, 09:38 PM
Genuine ones were good(despite melb subaru stealership network trying to charge $80 inc fitting!) when whe had a genuine windscreen, but when it fractured and was replaced they chattered.
  #7
Unread 12th July 2008, 12:35 AM
Rally's Avatar
Year: 2004
To each other?
  #8
Unread 12th July 2008, 03:52 AM
yep - couldn't shutem up :D
  #9
Unread 12th July 2008, 07:33 AM
eden's Avatar
bush bash'n ranga
cheers, Eden
  #10
Unread 12th July 2008, 09:31 AM
carljwnc's Avatar
carljwnc carljwnc is offline
carljwnc is on a distinguished road
Default '09 Forester Wiper Blades
I just replaced Blubaru's wipers with ones from the '09 Forester. They have an airfoil carrier and the drivers side blade is longer while the passenger side is shorter. They work GREAT!!! Lot's of folks on sf.org have done this and I haven't heard a bad thing yet.
