Go Back   OFFROADSUBARUS.COM > Offroad and Touring Central > Recovery Gear and Offroad Driving Tips
Unread 11th April 2012, 09:02 AM
Dulagarl's Avatar
Dulagarl Dulagarl is offline
Year: 2000
Model: EZ30R Forester
Transmission: Dual range manual
Dulagarl is on a distinguished road
Seriously, I reckon it looks ****.
Unread 11th April 2012, 05:53 PM
I would also question if it works with open diffs e.g. you could mount it on the rear and lose all your power through a front spinning wheel (or visa versa)
Unread 12th April 2012, 10:57 AM
taza's Avatar
taza taza is offline
taza is on a distinguished road
Won't work with open diffs and AWD. As you can get one wheel spin!
Current vehicle - 84 MY Wagon EJ22 4 Speed
Unread 12th April 2012, 11:50 AM
stilson's Avatar
stilson stilson is offline
stilson is on a distinguished road
Buy 4 wheel winches?
The Grey Fox - MY08 SG XT Luxury
  #15
Unread 12th April 2012, 12:11 PM
nipper's Avatar
nipper nipper is offline
nipper is on a distinguished road
Not true if you know how to pretend you have an lsd. If you slightly appl the brakes it shifts power from one wheel to another and acts like a lsd, and mimics how modern traction control works, after all that is all it does anyway.
  #16
Unread 12th April 2012, 08:17 PM
Gidday Kevin
I don't know when it was introduced, but Roo2 has LSD centre (standard since the 1993 Impreza) and an LSD in the rear.
It also has EBD, which according to some sources, is just a different name for traction control ... Both working by selectively applying individual brakes as required. I am happy to be corrected about this latter, as the Internet can be a very flaky source of information ... .
Upshot of all this is that the wheel winch should work well, but slow and difficult to deploy, and is much more expensive than buying an ARB Magnum creeper winch. The creeper winches are probably the most flexible of the lot, even beating electric winches for that aspect.
Other than running with them fitted to the rims all the time, just imagine trying to fit them when bogged to the eyeballs!
Last edited by Ratbag; 12th April 2012 at 08:51 PM. Reason: correction of relative pricing ...
  #17
Unread 13th August 2016, 04:41 AM
This seems like the kind of winch I want (except for the oddly looking wheel nuts).
Of course, it has been 6-7 years since the last Subaru that would spin a single wheel like crazy rolled off the assembly lines, so that is not a concern (on VDC models).
http://www.bushwinch.com.au/shop-products-2/
The current price in USD is 430sh vs 330sh for a high quality hand winch. Plus shipping. Though adding the ground anchor, which looks extremely useful, would make the total price fairly ridiculous for such a simple product. But it is precisely the simplicity I like.
May inquire about my car just to know if it is even an option.
  #18
Unread 14th August 2016, 10:18 PM
Not a fan. It would easily overpower the VDC system and the centre diff. Just stick to the tried & proven recovery tracks & winch
  #19
Unread 15th August 2016, 08:22 AM
subyroo's Avatar
subyroo subyroo is offline
subyroo is on a distinguished road
My old man and I used to use good old fencing wire. we wrapped it around the rear tyre, anchored the other end and slowly reversed the old Morris Cowley ute out of bogs or where we couldn't traction in the bush when it was wet.
Mind you, this was out in Riverrina NSW where it is flat too.
In hindsight, had the wire ever snapped it would have cut one of us in half or or taken our legs off.
Peter
2016 Honda CR-V
  #20
Unread 7th October 2016, 11:06 AM
Tannin Tannin is offline
Tannin is on a distinguished road
Wow! This is an amazing .......
...... price.
Too bulky for my liking. If you are going to cart something thast size around, why not cart an electric winch? And if you want something small enough to keep under your seat, a hand winch is the go.
(Had my hand winch for years. Used it exactly twice. Once to rescue a bloke in a Commodore who was somewhere he certainly should not have tried to go in that car, and once to move a 10,000 litre water tank. (Not a full one, of course.) We had to move it to one side to dig a big hole to lower it into so that the inlet was lower than the shed roof. Did that easy-peasy by attaching a webbing strap to the tractor. But you can't push on a string and trees meant that we couldn't tow it back into the new hole from the other side, so I winched it back with the trusty hand winch. Took maybe half an hour instead of five minutes with the tractor, but did the trick.Tank is now full and we are good to stand a couple of dry suimmers.)
tannin.net.au
