Go Back   OFFROADSUBARUS.COM > Reviews > Products
Unread 24th September 2015, 01:29 AM
idw's Avatar
idw idw is offline
Year: sf
Model: sf
Transmission: m
idw is on a distinguished road
Default J&R Stretch CVboot kits. Awesome
http://stores.ebay.com.au/J-R-CV-JOI...p2047675.l2563
I've been using this outfit in the UK to buy cv boot kits from, with a cone or pneumatic tool, it makes changing the boots a very quick little job, about 25min-30min per boot for me. Possible to do on a track if you rip one out completely. Cost is between $20-30AUD depending on exchange rate and kit purchased. Comes with boot clamps, grease,cone lube to stretch the boot, and a new most importantly a new crush nut.
The rubber seems (no evidence really) to stand up to the lift kit and heat of my exhaust better than the standard boots from subaru or oem from Bursons. Also alot harder to puncher a hole in.
Unread 14th October 2015, 08:36 PM
I'm not sure how these are faster, you still have to remove the outer cup which means pulling apart the CV?
Unread 15th October 2015, 03:36 AM
idw's Avatar
idw idw is offline
Year: sf
Model: sf
Transmission: m
Nar just turn it inside out and stretch it over like normal. Don't need to remove cups at all.
Unread 15th October 2015, 10:56 AM
So the small end of the boot that fits on the axle shaft stretches over the large green cup?
Unread 15th October 2015, 04:28 PM
Barnboy Barnboy is offline
Year: 2012
Barnboy is on a distinguished road
These are pretty good. I have used a couple of these for the front inner CVs on my old SF and probably did 40,000 miles on them without any trouble.
When I first looked at it, I thought how is this going to work, it can't stretch that much, but really was easy. Just knocked the pin out of the inner cv at the gearbox, put the fat end of the cone over it and then cover the cone in the lube they supply and pull the boot over.
2012 Manual SH Diesel Forester
Unread 15th October 2015, 08:34 PM
2x boots, $22 delivered
http://www.ebay.com.au/itm/2X-SUBARU...GkhXShI0WZlbCw
So this is how it works...looks great!
https://youtu.be/so9gMxzJH4k
Unread 15th October 2015, 10:54 PM
havachat's Avatar
havachat havachat is offline
Year: 2002
Model: Forester SG
Transmission: 1.447 low range 4.44 diffs
Do these do both the inner and outer ?
Unread 22nd October 2015, 07:04 AM
idw's Avatar
idw idw is offline
Year: sf
Model: sf
Transmission: m
Yes they do both inner and outer, there are 3 or 5 (2 for the shaft, 3 for the cv cup) sections you can cut the boots to so they can fit different sized cups and shafts. I usually don't bother cutting the boot to diameter for the shaft, since the little extra seems to help stop leaking. The inners i also don't cut on the subaru, mainly because im lazy, installed on outer joints the they need to be cut to size so they don't rub on the hub.
Unread 29th October 2015, 05:00 AM
tuckerbag tuckerbag is offline
tuckerbag is on a distinguished road
Do they do rear shaft boot? Im in need of 2 set. Cheers.
Unread 30th October 2015, 07:29 AM
idw's Avatar
idw idw is offline
Year: sf
Model: sf
Transmission: m
Yes I've them on the inner rears
