Go Back   OFFROADSUBARUS.COM > Technical Forums > Car Care
Unread 5th April 2012, 09:12 PM
98outbackguy 98outbackguy is offline
98outbackguy is on a distinguished road
Default Watter in the lights
My right fog light has a good bit of watter stuck in it and im not shure of the best way to get it out. Thanks
_____________________
Mike
Unread 5th April 2012, 09:15 PM
MONSTERSKULLS's Avatar
MONSTERSKULLS MONSTERSKULLS is offline
MONSTERSKULLS is on a distinguished road
I have the same problem on the left side headlight! well...only after I go swimming for a bit
Unread 6th April 2012, 02:38 AM
d_generate's Avatar
d_generate d_generate is offline
d_generate is on a distinguished road
Drill a tiny whole or 2 in the lowest part of the light, it'll drain & dry, it fixed the lights on my son's old Falcon and saves farting around trying to seal them.
98 Liberty,V3 STI conversion,13.0qtr almost stock
Unread 6th April 2012, 12:14 PM
Default Thanks
Thanks for the help I will defiantly try that but any idea how the water gets in I asume it's a hole somewhere but if there's a hole for it to get in id think it should have drained out.
many thanks
Mike G
98 Subaru outback legacy
Unread 6th April 2012, 01:15 PM
d_generate's Avatar
Nah usually the tops of the lights cop all the sun and the seals just deteriorate over time, no holes for drainage as they aren't supposed to leak, once the water is drained the heat from the sun/globes will dry them pretty quick. I think I used a 2mm drill bit or whatever was the smallest I could fit in the drill.............Just don't try to drill through glass but yours should all be plastic, if not hit the backing plates.
