Go Back   OFFROADSUBARUS.COM > Technical Forums > Car Care
Unread 7th March 2012, 05:44 AM
stilson's Avatar
stilson stilson is offline
stilson is on a distinguished road
Default Sand in the dang electric windows
After a play around in the sand (the dirty, dirty sand) I've got horrible noises coming from my windows when I wind them up or down.
I pulled back the rubbers and vaccumed everything, then washed, then steamcleaned and they still make this scraping sound. Do I have to pull my door trims off?
Please help me!
The Grey Fox - MY08 SG XT Luxury
Unread 7th March 2012, 11:13 AM
d_generate's Avatar
d_generate d_generate is offline
d_generate is on a distinguished road
More than likely need to take them off but thats the easy part, sand's probably got into the mechanism which crosses when they go up and down or into the tracks either side of the window or where the rollers are in the track down the bottom, either way it sounds like you'll need a tin of prepsol and a paint brush then a new tin of grease, I've driven both of mine extensively in the sand and never had a prob, yours sounds unusual, I wonder if someone has got into the doors with some extra grease.
98 Liberty,V3 STI conversion,13.0qtr almost stock
Unread 7th March 2012, 10:03 PM
stilson's Avatar
Cheers. Any advise on removing trims without damaging them?
Unread 7th March 2012, 10:28 PM
thunder039's Avatar
thunder039 thunder039 is offline
thunder039 is on a distinguished road
becarefull and take your time
99 subaru foz 89 brumby 04 forester xs
Unread 7th March 2012, 10:44 PM
stilson's Avatar
Damn I was hoping it wouldn't come to that.
Unread 8th March 2012, 02:56 AM
Get some trim removal tools:
http://www.jaycar.com.au/ShowLargeph...4&PRODNAME=Car Panel Removing Tools&IMAGE=
Unread 8th March 2012, 03:13 AM
Thanks Kevin
After some "off roading" I found the correct URL ...
http://www.jaycar.com.au/productView...l&form=KEYWORD
Don't you wish web site designers would keep delimit characters out of URLs ... ??
Wikipedia is among the worst offenders, and they really should know better!
Unread 8th March 2012, 04:44 AM
d_generate's Avatar
You have wind up windows??? otherwise just a phillips should be all you need, everything else just clips off....Hint, open door handle and push surround forward to remove and you'll find another screw in there holding the mechanism in place.
Unread 12th March 2012, 10:19 AM
stilson's Avatar
Thanks guys, got em off and on again no probs windows are a bit better too.
Unread 12th March 2012, 11:57 AM
d_generate's Avatar
Oh well a bit is better than bugger all.
