Go Back   OFFROADSUBARUS.COM > Technical Forums > Car Care
Unread 30th August 2008, 03:19 AM
Nephrurus Nephrurus is offline
Nephrurus is on a distinguished road
Default Paint Chip, now a tiny rust spot
Here we go, a use for this forum.
A piece of paint about 4mm square has come off, and is now rust coloured. Is there a way to fix it up or stop if getting any worse? I'm not worried about appearence, more that it'll cause problems down the track ($$$$ wise).
Cheers!
-Henry
Unread 2nd September 2008, 05:52 AM
ForesterGump's Avatar
ForesterGump ForesterGump is offline
ForesterGump is on a distinguished road
Unfortunatly now it is one of those things...the best (and really the only way to fix it properly) is to sand the chip out, prime the affected area and finally paint the panel.
But really anything covering it at all (bare metal doesnt really like the elements) is better than nothing. Try and get some sort of paint on it as quickly as possiable (even if you go to your local Panel shop and just ask them to do a brush touch on it - it wont last too long, especially if it has already started to rust, but as said earlier....it is better than nothing!)
Regards,
Brad
MY06 Forester X
Unread 16th October 2008, 10:38 PM
Tweaksta's Avatar
Tweaksta Tweaksta is offline
Year: 2000
http://www.touchupguys.com.au/
http://www.advancedpaint.com.au/
http://www.superfinishexpress.com.au...hipscratch.htm
http://www.1800bumper.com.au/
http://www.chipsaway.com.au/
http://www.thesmartguys.com.au/
There are quite a few......I also need to get some work done too so any reviews are always welcome.
Unread 30th November 2009, 09:35 AM
Ruggedcoast01's Avatar
Ruggedcoast01 Ruggedcoast01 is offline
Ruggedcoast01 is on a distinguished road
Default Temp chip repair
A tip I received from a dent/chip repair guy was to put clear (finger) nail polish on any small chips or scratches to stop corrosion. Not every little break in the paint is going to be worth a professional repair & the nail polish is tough enough to cope with weathering.
Unread 27th February 2011, 11:46 AM
challis challis is offline
challis is on a distinguished road
Default Paint chip
Henry, I discovered a paint chip about the same size as yours within a week of purchase. How it happened is unimportant. The bottom line is the dealer repainted the hood in about an hour. It looks brand new again! Take it to your local dealer. You will be happy with the results. This is not a big deal for them. challis
Unread 27th February 2011, 04:12 PM
carljwnc's Avatar
carljwnc carljwnc is offline
carljwnc is on a distinguished road
In the bicycle biz we always told folks to go the fingernail polish route. Very tough and with some careful selection and/or mixing, you can color match just about anything.
'07 Outback MT
'16 Outback CVT, EyeSight
Unread 3rd March 2011, 04:02 PM
PenguinSub PenguinSub is offline
PenguinSub is on a distinguished road
Hey, what do you drive, and where did you go? I'm originally from CT
