  #31
Unread 16th January 2015, 04:53 AM
Gidday Greeno
A warm to the ORS forum and its motley crew, mate ... .
AFAIK, fly by wire was introduced with the series I SG. If you have ever looked at the cruise control setup on the SF, you will be as amazed as I am that it even works at all!
All sorts of finesses of design become easily achievable with the removal of mechanical linkages.
It takes just one look at the incredible complexity of the hydraulics involved with any modern ABS and EBD braking systems to realise just how complex mechanical systems can make things. This in spite of the fact that the control systems of both ABS and EBD are electronic ...
It makes sense that the ECU would be different in the series II. After all, it has to control the variable valve lift technology and the tumbler valves, as well as having to deal with the MAF sensor input rather than using a MAP sensor, to name just a couple of obvious major changes.
  #32
Unread 18th January 2015, 03:36 AM
Greeno's Avatar
Greeno Greeno is offline
Model: Forester XS
Greeno is on a distinguished road
I have a 2004 sg forester and it is definatly cable operated throttle. The cruise is not the old vacuum operaterated unit but an electric one.
Thank you for the warm welcome
  #33
Unread 18th January 2015, 04:11 AM
^ That's interesting, Greeno.
It appears that the change to fly by wire occurred when the particular model became a ULEV certified vehicle (Ultra Low Emissions Vehicle). It is very hard to determine exactly when this occurred for any particular model ... .
  #34
Unread 18th January 2015, 07:58 AM
havachat's Avatar
havachat havachat is offline
Year: 2002
Model: Forester SG
Transmission: 1.447 low range 4.44 diffs
Hi RB,
Both my SGs are cable these are series 1 and are 2002 and 2004. I suspect the fly by wire would be from the series 2 SG which were released in 2005.
  #35
Unread 18th January 2015, 08:06 AM
Greeno's Avatar
Model: Forester XS
Also if you want to continue with this topic, the exhaust manifolds are also different. Mine come out of the heads and both run towards the rear of the vehicle before joining together, whereas the series 2's come forward and loop round the front of the engine (which i might add makes changing the oil filter on a hot engine a PITA)
  #36
Unread 18th January 2015, 08:57 AM
crazydave crazydave is offline
crazydave is on a distinguished road
Smile
Greeno,
I have to ask
what are you doing with your arse that close to the exhaust I can't even imagine the gymnastics you are up to
All jokes aside I completely agree warm it up to mix the oil but then wait 20 minutes for it to be cool enough not to burn your hand - doesn't seem very logical to me.
There must be a tool that can cup the oil filter and remove it without burning your had on the exhaust or the oil - but capture the oil so it isn't all over the exhaust - 6 oil changes later I still have not managed to not have oil over the manifold - usually soon followed by the misses asking if I have broken the car because it smells.
Back to the engine differences when I was researching the car to buy I found something that said FBW throttle was all part of the upgraded emission requirement as was the variable valve stuff, ecu and I think the exhaust. and that is all came in with the series 2 SG - cant remember the date.
2007 Forester X MT
  #37
Unread 18th January 2015, 06:09 PM
Gidday HC, Greeno and CD
Thanks for that info, fellas. Seems to me that the change to FBW must have occurred with the introduction of the series II, as Greeno has said. Mid-2005.
This makes the series II a ULEV model.
I suspect that our series I SH may be a PZEV, but can't be sure about this either.
Maybe it was the series II SH with the FB engine that introduced this?
  #38
Unread 19th January 2015, 08:52 AM
Greeno's Avatar
Model: Forester XS
Originally Posted by crazydave View Post
Greeno,
I have to ask
good on ya
  #39
Unread 19th January 2015, 04:09 PM
There must be a tool that can cup the oil filter and remove it without burning your had on the exhaust or the oil - but capture the oil so it isn't all over the exhaust.
On my '03 I usually cut a 1.25L soft drink bottle in half and slip the bottom of the half with cap over the filter - don't know if this will work on your '07
  #40
Unread 20th January 2015, 12:50 AM
Kevin,
Good idea.
I don't know if it will work either but on the next oil change I will give it a go. Hopefully I will be able to get my hand around the outside between the headers - wont solve burning the hands but will stop everything getting covered in oil.
2007 Forester X MT
ej-251, ej-252, ej-253, ej251, ej252, ej253, sg forester, sg series i, sg series ii
