Go Back   OFFROADSUBARUS.COM > Technical Forums > Bolt-On Bits, Accessories and Protection
  #1
Unread 8th August 2013, 01:19 AM
PigSti PigSti is offline
on sabbatical
Question Missing ECB bar mount bolts
ECB bar mount bolts
I can't believe it but I'm missing some mounting bolts! Took the front bar off to work on the car and now I have 6 bolts missing on both sides. The main chassis rear bolt with spacer I have but the 2 front chassis and 4 side bar bolts are gone.
Any advice on what to get because ECB couldn't care less unless you buy the whole mount again for $400, ORLY!
Any suggestions on sizes and strengths?
  #2
Unread 8th August 2013, 05:17 AM
Get high tensile - no idea of sizes, sorry. Shouldn't be hard to figure out; just measure the diameter and length.
  #3
Unread 8th August 2013, 05:18 AM
tuckerbag tuckerbag is offline
tuckerbag is on a distinguished road
I would put 8.8 grade bolts and size that fit the holes.
  #4
Unread 8th August 2013, 05:32 AM
mr turbo's Avatar
mr turbo mr turbo is offline
Year: MY05
Model: Forry XT
Transmission: manual
Yes 8.8 grade would be the go.
I'm fairly sure (99.9%) that's what I had on my nudge bar when it I had one.
BTW, whats the story with the dripping radiator fluid I can see there ?
  #5
Unread 8th August 2013, 07:42 AM
havachat's Avatar
havachat havachat is offline
Year: 2002
Model: Forester SG
PigSti pretty sure I still have the fitting instructions for the ECB bar. I assume it is the 2002-2005 Forester. The fitting instructions list all the bolts etc.
Will look tonight.
Can you confirm your model.
  #6
Unread 8th August 2013, 09:05 AM
havachat's Avatar
Year: 2002
Model: Forester SG
Here it is for the SG 02-05 model, however if you have the 05-08 model I suspect the bolt would be the same.
Trust this helps.
  #7
Unread 8th August 2013, 12:39 PM
on sabbatical
Question
Sorry but there is no link or pic for me to get. Are you sure that you have attached or linked the file?
  #8
Unread 8th August 2013, 06:43 PM
If can see - in the above post then click on it
  #9
Unread 8th August 2013, 10:28 PM
on sabbatical
Trust this helps.
Oddities of my client cookies no doubt but nothing visible for me here.
Perhaps try CODE tags instead?
  #10
Unread 8th August 2013, 11:00 PM
NachaLuva's Avatar
Trust this helps.
I cant see it either...
