Rust Prevention
Ben Up North
FNQ
2004 | 1992
SG Forester X MY05 | 92 SVX
5MT D/R | 4EAT
So I've drilled and cut a bunch of holes in my car (snorkel fit).
Question is: what's the best/easiest/cheapest thing to do to the holes for rust prevention?
I was thinking of just using sikkaflex, as I'll be putting a heap of that around the holes anyway.
Or should I treat the metal with some rust prevention stuff first, if so (and remembering I'm a cheaparse and Jack's a rat) what?
All suggestions considered!
I usually will give it spray with anti-rust paint available from Bunnings.
That's the way I was thinking of going. Not sure how to do the bits inside the guard pretty tight in there. It's about 98% humidity here at the moment, not the best painting weather...
With the inner guard shield removed, or partially removed, just spray it up there and hope for the best :iconwink:
Sika themselves recommend pre-treatment of some sort.
The guard's not really a worry - bolt on, bolt off.
I'd be very concerned and careful with treatment if you've put mounting holes in your A-pillar.
after welding metal we use Zink spray , could be good too. i used antirust paint too or some other 3in1 that you can paint on rust no matter. they hold very good.
Mmm. don't want that rusting out.
