  #141
Unread 2nd June 2018, 05:21 PM
jf1sf5's Avatar
jf1sf5 jf1sf5 is offline
Originally Posted by scalman View Post
Suspension travel makes grip plus lots going on in center and diffs there.
Don't forget the most important....the driver
Subversive...
  #142
Unread 3rd June 2018, 12:33 AM
scalman scalman is online now
Year: 2001
Transmission: 4eat
Yh smart driver can allways find other ways lines to go with its car capabilitys.
  #143
Unread 15th July 2018, 08:30 AM
jf1sf5's Avatar
@Dedman, your PM box is full....
Subversive...
  #144
Unread 15th July 2018, 08:31 AM
jf1sf5's Avatar
posted twice, sorry
  #145
Unread 19th July 2018, 08:47 AM
Dedman's Avatar
Dedman Dedman is offline
Year: 1999
Transmission: 5MT
Dedman is on a distinguished road
Originally Posted by Red XS View Post
Front - Coilovers that compress to 385mm (OEM shocks compressed length) and extend to 568mm (OEM shocks extended + 2inch lift blocks) = 183mm stroke
Rear - Coilovers that compress to 448mm (OEM shocks compressed length) and extend to 672mm (OEM shocks extended + 2inch lift blocks) = 224mm stroke
Red, how were these measurements of the original shocks taken? Like this or something else?
I have asked hotbits for stock length + 125mm and they lengths they have come back with are quite a bit longer that your measurements (taking into account the extra 75mm I asked for)...
99 Foz 2.0 n/a 50mm Strut, Kings, 9000lbs Winch, Offroad Bumper, Custom Sumpguard, Snorkel
  #146
Unread 19th July 2018, 09:46 AM
Red XS's Avatar
Red XS Red XS is offline
Year: 2006
Model: SG Forester XS
I would have got those figures somewhere of the internet and not measured myself, so I'm not really sure how they were taken or if they were even accurate as I was still learning at that stage. A bit changed since that post, so I might have to go back and edit old posts...
I ended up buying 210mm stroke front and 300mm stroke rear as you would see in later posts. Toh/Hotbits figures matched my oem shocks perfectly when I pulled them out, so I would recommend going with those figures. I do remember being surprised at how much shorter the official figures from brands including KYB were from oem.
  #147
Unread 19th July 2018, 01:03 PM
jf1sf5's Avatar
Dedman, you want to install a 3" body lift by the lengths you are giving !
Jeremiah22 sorted out the figures you need as he has already done it.
Get maximum stroke possible whatever the length you go for, it is easy to shorten the stroke with internal shims (nylon shims or tube)
Did you get my pm ?
Subversive...
  #148
Unread 20th July 2018, 09:12 AM
Dedman's Avatar
Year: 1999
Transmission: 5MT
Planning on a 2" body lift with 4.5 inch over standard front struts and 5 inch over standard rear struts. I have been told 2.5 on the front of an SG is workable.
Jeremiah22 has the figures for the SF. I think it will be different for a gen2 SG (which I have now).
Did you get my pm ?
Sure did, thanks mate. Just haven't got around to replying yet.
Good to hear. I am going to pull mine on the weekend and measure the lengths. I want to be certain before spending the large amount of $$$
  #149
Unread 22nd July 2018, 09:38 AM
Dedman's Avatar
Year: 1999
Transmission: 5MT
I pulled the SG struts and measured them.
Front
Extended: 555mm
Compressed: 390mm
Travel: 165mm
Rear
Extended: 642mm
Compressed: 422mm
Travel: 220mm
So for my hotbits I am after
Front extended length: 670mm
Rear extended length: 770mm
All the above measurements were taken like this:
  #150
Unread 19th August 2018, 05:59 PM
jf1sf5's Avatar
Re-read the HotBits thread and remembered I wrote this about the lengths, oem front struts
SG5 ('03-'05) center of lowest bolt to top of thread is 600mm, or to first step is 562mm. Shaft stroke 185mm. Center of lowest bolt to spring perch 225mm, spring perch 2mm, spring perch to end of housing 150mm.
Would be interesting to know why there is such a difference...
Subversive...
