  #1
Unread 7th August 2008, 05:24 AM
eden's Avatar
eden eden is offline
bush bash'n ranga
eden is on a distinguished road
Question Replacment shocks. what did you get
well it seems everything is going at once i now need new shocks as well as a gearbox. so what have you guys used (brands and type) and from where? i think i recall Carlo getting replacments from someone in penrith?? is that right mate or am i imagining things anyway let me know, any info will be good especially those with outbacks 98-03
cheers, Eden
2000 outback, subX bullbar + sumpguard,50mm raised strut blocks,30mm raised springs,215/65/16 rubber,uhf, dual battery system,150W spots,touchscreen navigation with oziexplorer. more to come
  #2
Unread 7th August 2008, 05:46 AM
mr turbo's Avatar
mr turbo mr turbo is offline
Year: MY05
Model: Forry XT
Transmission: manual
I got all of my suspension done at Wholesale Suspension at Penrith.
The springs were 30mm raised King Springs (190 pounds) all round.
I also put KYB Struts in at the same time. (4x)
I had to change the struts due to the self leveling (rear).
I was & still am very pleased with them & have never looked back.
Wholesale Suspension was recommended to me by Kevin (thanks mate) & I would also highly recommend them to anyone that wants & / or needs any work done.
  #3
Unread 7th August 2008, 06:36 AM
eden's Avatar
bush bash'n ranga
so you got standard struts on the rear? do you by chance have the number for those guys
cheers, Eden
  #4
Unread 7th August 2008, 07:15 AM
mr turbo's Avatar
Year: MY05
Model: Forry XT
Not quite sure if they are standard or not, but I will find out for you.
All I know is that I had to do away with the self leveling struts in the rear due to springs being raised.
Ph (02) 4721 2112
  #5
Unread 7th August 2008, 08:13 AM
eden's Avatar
bush bash'n ranga
good on ya Mr T will give em a ring tomorrow
cheers, Eden
  #6
Unread 7th August 2008, 09:09 AM
spinners's Avatar
spinners spinners is offline
Moderator
spinners is on a distinguished road
I had mine done with Wholesale Suspension at Blacktown.
Wholesale Suspension Blacktown 1/47 Third ave Blacktown,
NSW 2148
(02) 9831 8825
I needed to replace my self levellers as one had failed. I went with the KYB Excel-G gas replacement struts. Love them. I'll put the same on the front when the time comes.
Don't go with the Boge's if they offer them. They will say that they are cheaper. They are, and they get a kick back for selling them also. They are virtually identical to the KYB's, but I've heard some poor stories and recommendations. Stick with the KYB's.
I had STANDARD HEIGHT HD King Springs installed in lieu of raised. If you look in the King Spring online catalogue, they'll say that they don't exist but they now do. Best thing is to ring and find out.
Eden, as you have the 50mm body lift, you could go the 30mm raised springs and get a little more lift
Regards,
Carlo
"Improvise, Adapt & Overcome"
  #7
Unread 8th August 2008, 12:33 AM
Yep, stick with the KYB Excel-G and Kings. It's all good.
MY'97 Outback RIP
  #8
Unread 8th August 2008, 12:00 PM
Brendon Brendon is offline
Brendon is on a distinguished road
Don't you already have raised King springs Eden?
  #9
Unread 8th August 2008, 08:01 PM
eden's Avatar
bush bash'n ranga
right you are. but i will have them checked (the rear ones) when i have the struts done because i have about 200Kg of tools in the back and i think over the years they have sagged a bit
cheers, Eden
  #10
Unread 11th August 2008, 10:24 AM
Hilly Hilly is offline
Hilly is on a distinguished road
Just had the rear struts on my '03 Forrie replaced with KYB Excel-G (I've just got to the 100,000km mark). They seem nice, I wouldn't mind them being firmer, but they are much better than what the Forries struts were when they were new! I remember when i test drove and bought the Forrie, and wishing the struts had firmer valving, way back then. I've got the old Suba-xtreme heavy duty springs, standard height - still going well, no sagging yet, and they have had a hard time, done about 70,000km on those, a lot of that loaded pretty well.
I probably need to replace the front as well, and I'll go the same. I was going to get Bilsteins on th eback, but they don't have a model for the '03 - they suspension guy said he could put them on, but would have to modify the way the brake hose is attached, which he preferred not to have to do.
