Go Back   OFFROADSUBARUS.COM > Technical Forums > Under the Bonnet/Hood
  #1
Unread 9th May 2018, 02:52 AM
turbo1600 turbo1600 is offline
Year: 1998
Model: outback
Transmission: auto
turbo1600 is on a distinguished road
Default problems with fuel consumption
i`m only getting 300- 350 km per tankful. in `98 outback , i`ve checked o2 sensor 450 to 550 mv at 80kph , getting bout 13v and 1.1 v on MAF , when i pull maf connector of engine stalls, any thing else to check ? car idles and runs fine.
mk
  #2
Unread 9th May 2018, 04:44 AM
Ben Up North's Avatar
can only hope to improve
Year: 2004 | 1992
Transmission: 5MT D/R | 4EAT
Dunno if it's relevent or not but...
My 04 forester's fuel gage shows almost empty while there's at least 20L in it. it's way out.
What's your actual fuel consumption?
  #3
Unread 9th May 2018, 08:01 AM
El_Freddo's Avatar
Year: 1988
Model: EJ22'd L series
Classic issue this one!
My L series regularly gets between 350-520ish kms "per tank".
But what's not mentioned is how much fuel I put in each time I fill up.
You need to work out how many litres per 100km. The best I manage to squeeze out of my L is 10L/100km on primarily open road driving - I still can't help but give it a kaining too. So I'm pretty happy with that considering I'm lifted with a roof rack and spare up top.
Worst I've had was. 15L/100km - on sand 4wdn and when crossing the Nullarbor with a head wind and a wind sock up top and the car loaded to the gills in general running AC.
So can't complain on those figures.
I'll be keen to read your figures when you work them out.
  #4
Unread 9th May 2018, 08:45 AM
This means your sending units in the tanks are crook; as are mine btw. I just rely on my scanguage.
MY'97 Outback RIP
  #5
Unread 26th October 2018, 07:46 AM
ABFoz ABFoz is offline
Year: 2005
Model: Forester XS
Transmission: 4EAT
ABFoz is on a distinguished road
@turbo1600, have you already checked the PCV valve? Being a '98 that valve may already be somewhat clogged and will impact fuel consumption. It's relatively cheap to replace. Cheers.
