Go Back   OFFROADSUBARUS.COM > General Forums > New Member Introductions
  #11
Unread 25th April 2018, 02:34 AM
Tweaksta's Avatar
Tweaksta Tweaksta is offline
Senior Member
Year: 2000
Transmission: 5MT
Tweaksta is on a distinguished road
That is a f***king beast!
"Ridge" the Forester GT - 3" turbo dump - 5MT - Paranoid 1" lift + 30mm Raised King Springs & KYBs.
  #12
Unread 25th April 2018, 03:22 PM
fozroamer fozroamer is offline
Year: 2010
Model: Forester XT
Transmission: 4EAT
fozroamer is on a distinguished road
Originally Posted by scalman View Post
nice car man. we need info about it . lift tires other mods .
For Sure. I had a full mods list on my website but a few things were corrupted when I took it down. Been working on a new one via Google Doc will share once I get it completed.
In the meantime here is another pic by Kolor Photography.
  #13
Unread 25th April 2018, 08:53 PM
Year: 2010
Model: Forester XT
Transmission: 4EAT
Current Mods List:
Suspension
Custom 4” ADF Monster Lift - 4” Front 4 ⅜” Rear (” Steel)
Four Strut Spacers
Two Brace Arms
Two Reinforced Rear Subframe Arms
2” Subframe Spacer
Brake Line Brackets
Steering Shaft Extension
Crossmember, Trans, and Engine Spacers
King Springs Front/Rear (Standard Height)
KYB Struts Front/Rear
Moog Rear LCA (Adjustable)
Stainless Steel Braided Brake Lines - Extended
Engine:
Grimmspeed Downpipe
Grimmspeed Top Mount Intercooler
Grimmspeed Turbo Heat Shield
Grimmspeed Air Oil Separator
Grimmspeed Silicone Radiator Hoses
Grimmspeed Radiator Shroud
Grimmspeed 3” Downpipe Adapter (SKU: 077044)
Grimmspeed Air Intake (Custom water sealed setup coming soon)
Frenetic Fabrication Straight Pipe Exhaust (Routes Over Rear Diff)
Air Intake Water Sealed Snorkel Setup (Custom with Spectre Performance Parts)
Mishimoto Radiator (All Aluminum)
Hayden Automotive Transmission Cooler - Plate and Fin (1677)
Derale Engine Oil Cooler w/ Sandwich Adapter (15405)
Derale 12” Fan/Shroud - 1450 CFM (DER-18212)
Cobb AccessPort (Stage 2 Tune w/ TurboTekTuning)
Velox Hood Vents - BRZ
Vei Systems Dual Gauge (Oil and Trans Temps)
AEM Wideband (Coming Soon)
Tires and Wheels
Falken Wildpeak AT3W All Terrain Tires (30x9.5)
Black Rhino Boxer Wheels (15” 5x100 +15 offset)
Electrical
Switch Pros 8100 (Main Switch Device for Accessories and Lights)
Nilight Front Round LED
DJI Front Square LED Side Shooters
GG Lighting Square Pods (Installed on custom side view mirror mounts)
GG Lighting Rear Flush LED Lights (Inside rear bumper)
GG Lighting 30” LightBar Roof
Flush Rear Hatch LED Lights (Custom)
National Luna Portable Power Pack Dual Battery Setup
Blue Sea 5025 Fuse Block
Odyssey Group 31 PC2150M Marine Battery (Auxillary Battery)
Odyssey Group 35 PC1400T Battery (Starter Battery)
Renogy 100w Solar Suitcase
Bar Work and External Modifications
Frenetic Fabrication Front Bumper Tube Steel - Custom (with winch access)
Frenetic Fabrication Aluminum Sliders - Custom (mounted to subframe and B-Pillar)
Leadfoot Rear Plate Steel Bumper - Custom (Replacing May 2018)
Leadfoot Roof Rack - Custom
Ara MetalWorks Rear Tube Bumper (May 2018) - Dual Swing Arm (Modular)
CBI Dual Jerry Can Holder
Synergy (Poly Performance) Heavy Duty Spindles
Expedition One Custom Latches (Patent Pending)
Front Runner Outfitters Drop Down Table
AtoZ Steel D-Ring Recovery Points
Vehicle Accessories (Camp and Recovery)
Scout Equipment Overland Kitchen - Custom (2.5 Gallon Electrical Powered Water system, Sink, Cutting Board, Storage Drawers for Dry Goods and Cutlery)
Rhino Rack FoxWing
Smittybilt 9500lb Synthetic Winch
ARB 50 quart Fridge
Snow Peak Single Burner Baja Burner
Bomber Products AwnLock (For FoxWing)
Factor 55 ProLink Shackle (For Winch)
Factor 55 Hawse Fairlead
ADF Molle Rear Window Mounts - Two (Molle Mount system)
Freespirit Recreation ReadyLight (Solar Powered)
HiLift Jack
Wavian 5 Gallon Jerry Can (Two)
Front Runner Outfitters 5 Gallon Water Jerry Can
Viair 88P air Compressor
Tred 1100 Recovery Mats
BlueRidge Overland Rear Tire Setup - Modular (Trash Bag and Bag for Treds)
Drifta Recovery Bag
Comms
Cobra CB 74-WXST 40 Channel Radio
Firestick CB Antenna (3ft)
Trailer
Freespirit Recreation Overland Trailer
Freespirit Recreation High Country Tent (Large)
Freespirit Recreation Annex Room
RoadShower 4 (Seven Gallon)
Rhino Rack Vortex Crossbars
Rhino Rack Mesh Basket (Medium)
Timbren Axle-less Offroad Suspension (2500HD)
Matching Tire/Wheel Setup
MaxCoupler Hitch (360 Rotating Offroad Hitch)
Adapter Kings Wheel Adapter (5x114-->5x100 1.5”)
  #14
Unread 26th April 2018, 04:51 AM
Oh - is THAT all
  #15
Unread 26th April 2018, 06:58 AM
Ben Up North's Avatar
can only hope to improve
Year: 2004 | 1992
Transmission: 5MT D/R | 4EAT
Good Lord that's a lot of stuff done, awesome!
A bigger fridge so you can fit food in as well as beer and it would be perfect!
