Go Back   OFFROADSUBARUS.COM > Technical Forums > Under the Bonnet/Hood
  #1
Unread 21st October 2017, 01:02 AM
Ben Up North's Avatar
can only hope to improve
Year: 2004 | 1992
Transmission: 5MT D/R | 4EAT
Default Overheating when stationary or under load.
I've got a 2004 SG Forester, after the engine has warmed up, it gets massively hotter (noticeably above second line on temp guage) when stationary or climbing steeper grades - higher revs seems to cool things down (i.e changing back a gear when climbing). Cruising on the flats it's as cool as a cucumber.
Any suggestions? fans are kicking in, could it be a water pump issue or a blockage/flow restriction somewhere?
Any helps would be goods,
Ben
  #2
Unread 21st October 2017, 01:13 AM
Year: 2004 | 1992
Hmmm.. maybe it's a coolant issue. The stuff in there is green, and everyone here seems to be talking about blue stuff.
  #3
Unread 21st October 2017, 04:28 AM
Year: 2004 | 1992
Further to this.. increasing the revs when stationary rapidly lowers the temperature guage.
Which seems to imply to me that it's a flow through the motor thing.
  #4
Unread 21st October 2017, 06:13 AM
I would suspect the water pump. Green coolant is fine.
MY'97 Outback RIP
  #5
Unread 21st October 2017, 08:30 AM
havachat's Avatar
havachat havachat is offline
Year: 2002
Model: Forester SG
You could have a thermostat issue.
  #6
Unread 21st October 2017, 01:26 PM
jf1sf5's Avatar
jf1sf5 jf1sf5 is offline
What havachat says and OEM only.
Subversive...
  #7
Unread 21st October 2017, 06:20 PM
^ Ah yes I agree, of course, the thermostat completely slipped my mind!
MY'97 Outback RIP
  #8
Unread 21st October 2017, 08:17 PM
El_Freddo's Avatar
Year: 1988
Model: EJ22'd L series
Also check your heater circuit. If there's a blockage this can cause issues with the heating of the thermostat and thus it's opening.
That or you've lost coolant somewhere and have low coolant level... Long shot?
  #9
Unread 22nd October 2017, 12:37 AM
duncanm's Avatar
duncanm duncanm is offline
Year: 1998
Transmission: 5MT DR
revs when stationary suggests (as above) a partial blockage maybe.
Check for kinks in the lower hoses, pull the thermostat out and check it.
TT Outback
  #10
Unread 22nd October 2017, 03:47 AM
Year: 2004 | 1992
Thanks everyone for all the suggestions.
I'm going to take a guess that they didn't burp it when they checked for leaks, because I just added a heap of coolant and it's made a hell of a difference. The resevour was full though, so not sure what's going on there, or even if that would be expected, seeing as the radiator was so low..?
