  #11
Unread 20th September 2017, 03:20 AM
andymccauley andymccauley is offline
Year: 81
Model: DL
Transmission: Manual 4spd
andymccauley is on a distinguished road
So, I'm gunna be pulling this EA81 out soon, it's basically just sitting in the engine bay, everything is unbolted. Planned on using the flywheel for the swap, but I'm not sure on what clutch kit to get...
From what I've been reading the Xt6/ea82 kits are basically the same nowadays. But will they bolt On and work correctly to a ea81 flywheel and in the ea81 d/R 4spd?
  #12
Unread 24th September 2017, 12:15 AM
Year: 81
Model: DL
Well pulled the EA81 today, pressure washed the engine bay real good and found out that thing had a brand new luk clutch attached to it, so now I don't have to buy one.
  #13
Unread 25th September 2017, 04:13 AM
Year: 81
Model: DL
Some minor stuff today. Removed the water pump and cleaned the gasket surface, the paper gasket was torn in the box so waiting on one from amazon.. crossover pipe o-rings, new coolant hoses from the block to intake, intake bolted on.
Just need a rear main, rear block seals and the flywheel resurfaced and I think I'll be good to go.
  #14
Unread 28th September 2017, 06:37 PM
Year: 81
Model: DL
Got the EA flywheel resurfaced, and hammered the EJ pilot bearing out a little, the EA and EJ pilot bearings are the same diameter so used the EJs as a guide and then painted where the EA flywheel holes need to be messaged.
  #15
Unread 2nd October 2017, 12:03 AM
Year: 81
Model: DL
Pressurewashed the bejesus out of the of the long block, busted out the timing belt, timing covers, test fitted the adapter plate and changed the rear main.
Just need to finish the flywheel, open up the crossmember holes, and get the rear block plates off to reseal them. Slap the flywheel and clutch assembly, drop the motor in then start wiring, get a fuel pump, and change fuel lines. Just a small list lol
  #16
Unread 2nd October 2017, 12:13 AM
Year: 81
Model: DL
Picked up these 15x8s with 4" backspacing today for $50 was gunna get a carbite bit to get the flywheel going but the hardware store was closed already...
  #17
Unread 2nd October 2017, 09:45 PM
NachaLuva's Avatar
Hey Andy, good score on the rims!
When you post pics, pls change the size setting so we can look at the photos more easily. You'll find it on the host site, usually when you hit the share button.
  #18
Unread 3rd October 2017, 01:09 AM
Year: 81
Model: DL
What's a good hosting site since photobucket pooped on everyone I've been looking for one, been using imgbox which is easy to use but for some reason pics show up huge on this site, they're fine on any other site.. But there is literally no customisation with that host
  #19
Unread 3rd October 2017, 01:10 AM
Year: 81
Model: DL
The second one is always better than the first attempt. But the holes are open and should work just fine for the motor mounts.
  #20
Unread 3rd October 2017, 05:32 AM
NachaLuva's Avatar
I use Flickr, you can customize the size shared & sort your photos into albums
