Go Back   OFFROADSUBARUS.COM > Technical Forums > Interior and Exterior
  #1
Unread 6th May 2017, 10:03 AM
havachat's Avatar
havachat havachat is offline
Year: 2002
Model: Forester SG
Default How do I remove SH Forester rear seat
Need some advice. I need to remove the rear seat cushion on the 2011 SH.
  #2
Unread 6th May 2017, 08:10 PM
Ratbag's Avatar
Ratbag Ratbag is offline
Year: MY06, MY10
Model: Forester SG & SH
Haven't looked at our SH, but with the SG there are two bolts at the front in the foot wells, then you can get at the two at the back of the squab.
  #3
Unread 6th May 2017, 09:15 PM
havachat's Avatar
Year: 2002
Model: Forester SG
Totally different RB.
Finally worked it out.
Open cup holder and using a flat head screw driver gently prise up bottom cover.
Remove 4 x 10mm bolts.
Disconnect white plug to power cable.
On the left hand and right hand front corners of the seat lift up to disengage clip. This will require some force!
The fixing seems to be totally over engineered. Any way there you have it.
