  #91
Unread 2nd June 2018, 09:49 PM
Ben Up North's Avatar
can only hope to improve
Year: 2004 | 1992
Transmission: 5MT D/R | 4EAT
That car (I guess you can still call it that) is truly amazing. Mind you, your daily is amazing too!
  #92
Unread 28th August 2018, 05:58 PM
Jeremiahs22 Jeremiahs22 is offline
Year: 1998
Model: Forester S
Transmission: Auto
Jeremiahs22 is on a distinguished road
I am back to work on Ol' Silver, but not in the physical yet. So a couple months back, I tested the foz out at the dike by running it through whoops and hitting two little jumps at only like 45mph (the nurple did this section at about 55 to 60mph with the Hotbits). We got back to the shop and found the front coilovers rubbing on each other and the left side cantilever rotated out of whack. The mounting plate for the cantilever had bent up around the bolt that goes through the frame rail. I suspected this would be the failure point of the cantilever setup, but it was still a bummer.
Fast forward to now: I have motivation again, so I designed some lower control arms to allow me to mount the shocks vertically like a truck. I always thought there wasn't enough room but I mocked it up recently and there is just barely enough room. So once I get these cut out and put together, I will make upper coilover mounts and then hopefully the front will done for the most part.
Screenshot (7) by jeremiah stewart, on Flickr
Screenshot (8) by jeremiah stewart, on Flickr
The next project will either be changing the rear suspension or building a cage with a spare tire mount that will stick out through the hatch and hold two spares vertically with the fuel filler neck between them. That should help the weight distribution a bit.
I should also note that I have decided to change focus on this build. I do not plan on racing it anymore. I just want to make it a little pre-runner and use it to keep getting better at fabrication and to keep learning more about suspension design.
  #93
Unread 24th December 2018, 02:01 PM
Year: 1998
Model: Forester S
Transmission: Auto
So a few months ago I got my LCA pieces and started to weld them together and also started trimming the fenders for 33's. I also started making a tow bar for it so I can pull it behind my GX470 though i'm not sure it'll be as good of an idea as I think it is. Currently all projects are unfinished, including the roof rack I made for the Lexus that is now completely rusty lol. It's a PITA having to do everything at my work because I have to be able to get the car in and out of the shop in one weekend which often means that I tear it down to get measurements or to mock stuff up then have to put it all back together just to drive it home and let it sit for a couple more weeks.
20181130_211902 by jeremiah stewart, on Flickr
20181130_190918 by jeremiah stewart, on Flickr
  #94
Unread 24th December 2018, 08:21 PM
I'm very jealous of your welding skills!
MY'97 Outback RIP
  #95
Unread 17th March 2019, 12:43 AM
Year: 1998
Model: Forester S
Transmission: Auto
I finally got the front end done, and even welded together some rear axles and swapped the 33x12.5r15's onto the Methods. Did a few test runs in the snow, and there seems to only be a few issues, one being that the center differential is very lazy and stupid so i will need to wire up a lock switch. The other issues are the drivers side rear cv axle pulling apart (I must've made it a tad bit too short), it needs real bumpstops, and the headlights and dash lights don't work.
Need to clean up the engine bay a bit:
20190303_131516 by jeremiah stewart, on Flickr
DSC01016 by jeremiah stewart, on Flickr
I made a tow bar and wired the rear Subaru trailer plug to the Lexus' 7 pin plug so it has lights:
DSC01184 by jeremiah stewart, on Flickr
Got the side windows tinted 15% and had this beautiful Tecate decal printed by my buddy:
DSC01350 by jeremiah stewart, on Flickr
DSC01357 by jeremiah stewart, on Flickr
DSC01353 by jeremiah stewart, on Flickr
DSC01341 by jeremiah stewart, on Flickr
After I fix the axle, i'll get some videos of this thing.
  #96
Unread 17th March 2019, 01:55 AM
All I can say is - WOW it's awesome!
MY'97 Outback RIP
  #97
Unread 17th March 2019, 07:21 AM
jf1sf5's Avatar
jf1sf5 jf1sf5 is offline
Beautiful, can't wait to see the video, must be noisy though....
Subversive...
  #98
Unread 17th March 2019, 05:45 PM
scalman scalman is offline
Year: 2001
Transmission: 4eat
looks sick , wow but that front radiator unprotected... ouch, and its looks low that front is so low to ground ...with all that flex its so low
  #99
Unread 17th March 2019, 07:46 PM
Year: 2004 | 1992
That engine looks sooo good in there.
If it was a straightforward process I'd so be shoving my EG33 into my Foz.
As it is, I'm facing the hard decision on which one to repair first. The SVX needs brake work (still) and registration and the Foz... two words... Head Gasket.
  #100
Unread 17th March 2019, 08:49 PM
NachaLuva's Avatar
Looks great, that articulation is amazing!!!
The radiator/approach angle is a bit of a worry, any plans to lift that out of the way?
