Go Back   OFFROADSUBARUS.COM > Offroad and Touring Central > Trailers and Vans
  #21
Unread 15th February 2015, 11:10 AM
zippo zippo is offline
Guest
Year: 2007
Model: Forester X
Transmission: 5MT
zippo is on a distinguished road
Originally Posted by lefty View Post
Flipping the axle is the least attractive option as the trailer will be too high for the Foz.
Phil, there are a range of hitches that you can choose from that give you a variety of ball heights so that your trailer will sit level.
  #22
Unread 15th February 2015, 06:44 PM
Ratbag's Avatar
Ratbag Ratbag is offline
Year: MY06, MY10
Model: Forester SG & SH
And it will be OK anyway. Tandems have to sit level; single axle can be at any angle, even crazy ones, as long as the hitch doesn't bind (unlikely to happen).
  #23
Unread 15th February 2015, 09:02 PM
crazydave crazydave is offline
crazydave is on a distinguished road
Lefty,
I donít know about 13" rims being the easiest option - 13" rims with a holden stud pattern - can you get those these days?
Looks like the shackles come in up to 4" off the shelf that may be enough - how much clearance do you think you need?
2007 Forester X MT
  #24
Unread 15th February 2015, 09:44 PM
Ratbag's Avatar
Year: MY06, MY10
^ I would be inclined to go for slightly shorter shackles, and ask the trailer bloke how much to extend the front eye fixing point down an inch or so.
Get him to give you a report on the trailer condition generally while he is looking at it
Worth asking the questions, I reckon.
  #25
Unread 15th February 2015, 11:20 PM
lefty's Avatar
lefty lefty is offline
Year: MY05
Transmission: XT lux manual
lefty is on a distinguished road
quite a few 13" HR rims on gumtree. It's the quickest solution since I still need my trailer over the next few weeks (front yard renos yay)
MY05 XT Forester Lux manual
  #26
Unread 16th February 2015, 04:37 AM
Ratbag's Avatar
Year: MY06, MY10
Lefty, smaller rims will have no effect at all on your spring to chassis clearance. It may help with the wheel to guard clearance, but not your spring problem.
  #27
Unread 16th February 2015, 07:04 AM
Lefty,
Depends where the contact is, if it is wheels in guards then yes smaller wheels will solve the problem.
If it is springs hitting the frame - (which is what is looks like based on one of your earlier photos) it is spring hangers, longer shackles or springs or all of the above. or don't load the trailer as much/ live with the bottoming.
If you don't have a welder and a drill press the only realistic DIY is purchased longer shackles and a couple of spanners- also the cheapest and easiest diy option.
I notice you are in Perth Martins trailer parts will have the shackels and will probably be able to make some custom longer ones if they don't have what you need.
In the absence of DIY it is of the to trailer repair place and pay the $
2007 Forester X MT
  #28
Unread 17th February 2015, 08:29 AM
lefty's Avatar
Year: MY05
now I know for sure the leafs are too soft.
Got 1 scoop (half trailer) of rainbow stone - and it's almost bottomed out.
No way it could handle 2 scoops which is 1 full 6x4 trailer load.
so it's off to a trailer shop when I get the chance to get this sorted properly
thanks for all the advice
  #29
Unread 17th February 2015, 08:51 AM
Ratbag's Avatar
Year: MY06, MY10
Gidday Lefty
For all that they look to be mightily strong, they are patently as rooted as a good tree! I reckon that the existing springs are only managing about 300 kgs load capacity each, if that. Ugly ... .
I see some new springs in your future. My advice is not to go overboard with them. 600-700 Kgs each should be fine. Any stronger will just make your trailer as bouncy as a truckie on beans ...
Keep your 16" rims and tyres.
Mine were 610 Kgs capacity each when new, 35 years ago. Probably a little less now, but they have held up remarkably well. They are about the only things that Jimi was more than just happy to leave alone, so that says something.
My trailer isn't fantastic when I hit 20 kmh speed bumps at 40 kmh (empty), but is fairly smooth at 20-25 kmh - i.e. doesn't try to bounce into a neighbouring garden . That's without shocks. Considerably better now the tent is bolted on, as that adds around 100+ Kgs static load.
  #30
Unread 24th February 2015, 11:37 PM
Ratbag's Avatar
Year: MY06, MY10
Gidday Lefty
How did you get on with your problems, mate?
