Go Back   OFFROADSUBARUS.COM > Technical Forums > Under the Bonnet/Hood
  #11
Unread 30th December 2013, 09:51 PM
Rally's Avatar
Rally Rally is offline
Year: 2004
The topography of WA to Switzerland could hardly be more different....
SG turbo, 99 WRX, PX2 Ranger
  #12
Unread 31st December 2013, 02:04 AM
taza's Avatar
taza taza is offline
However if you you go down this route and want to go ej25 I'd highly recommend going a complete aftermarket computer. While my ej20 ecu works with piggyback system it's not ideal. I believe that huge gains could be available in the engine efficiency if the engine had a good tune to back it up.
  #13
Unread 31st December 2013, 04:12 PM
jf1sf5's Avatar
jf1sf5 jf1sf5 is offline
Yes, but we all need torque !
Subversive...
  #14
Unread 31st December 2013, 04:15 PM
jf1sf5's Avatar
Thanks Taza for all the feedback, I think I'll go the easy way...EJ22 but non-interferential, that means >'96 model, right ?
Subversive...
  #15
Unread 31st December 2013, 06:00 PM
Rally's Avatar
Year: 2004
Yes, and that is my point. For the most part WA is flat although the sand hills might be a different story. Even at it's highest point, it is nothing like Switzerland and what works great in WA might not necessarily do so in Switzerland. Depends too on the load. Good luck.
  #16
Unread 1st January 2014, 12:05 AM
taza's Avatar
Your dead right Rally! Our condition here are very different
The torque factor between engines is huge.
We do have hills here but nothing like you guys do over east or over seas. How ever with sand dune climbs that's where the torque is most noticable. I have the ability to climb hills in a higher gear at 1/2 to 2/3 of the rpm of what I'd have to with the 2.0l and in a lower gear.
The biggest downfall I have with the new engine is fuel economy. I believe this is due to my computer setup and tune, soon to be rectified though.
  #17
Unread 3rd January 2014, 02:30 AM
FozzyMatt's Avatar
FozzyMatt FozzyMatt is offline
FozzyMatt is on a distinguished road
If i were to change the engine block over at the same time I would go with the ej22 I think, mostly for making things simpler. However, if I was going to go to the effort of doing something on that scale I'd probably like to consider going the whole way and changing to the ej25. Unfortunately like with many things this is going to have to be ruled by cost. There's a fair few of the ej22's floating around that are reasonably priced though, and if the block is all I'd need I wouldn't necessarily be up for that much...
  #18
Unread 17th November 2017, 12:44 AM
Macca1963 Macca1963 is offline
Year: 2014
Transmission: Cvt
Macca1963 is on a distinguished road
Hi guys,
My 2014 Foz has over 98,000 kms on it, wondering when I should replace the timing belt, some say 100,000, 112,500 others sat 125,000.
  #19
Unread 17th November 2017, 02:37 AM
I believe it's now 125k kilometres down-under. It's still around the 100-150K MILES in the US! The difference makes no sense at all.
MY'97 Outback RIP
  #20
Unread 18th November 2017, 02:29 AM
Year: 2014
Transmission: Cvt
Thanks Kevin
