  #111
Unread 12th May 2018, 12:28 PM
Rally's Avatar
Rally Rally is offline
Year: 2004
Long time between bleeds. Much of the improved pedal feel would be from just bleeding the brakes. I run braided lines on my wrx. I bleed the brakes annually and when I do the pedal always feels better afterwards. That’s after just 1 year
  #112
Unread 14th May 2018, 12:51 PM
Fuze911's Avatar
Fuze911 Fuze911 is offline
Year: 2007
Model: Impreza Wagon 2.5L
Transmission: 4EAT
Fuze911 is on a distinguished road
Good to know. It's easy enough to do. I'll just be sure to do it annually and win win.
:bananagunner::banana::bananatoast::sadbanana:
Last edited by Kevin; 14th May 2018 at 08:02 PM. Reason: Unnecessary use of "Quote"
  #113
Unread 14th May 2018, 05:33 PM
Rally's Avatar
Year: 2004
Upside is less chance of corrosion and brake fade
  #114
Unread 16th May 2018, 01:30 AM
Fuze911's Avatar
Year: 2007
Transmission: 4EAT
Ok, so I’m getting a side to side type vibration on acceleration between 50-65 mph. Smooth as glass otherwise when off the throttle. Guess one of my axles took a dump? Or can it be something else?
  #115
Unread 16th May 2018, 03:37 AM
Torque steer / vibration can be caused by tires; try swapping them side to side and see what happens.
  #116
Unread 19th May 2018, 02:07 AM
temmah temmah is offline
Year: 2016
Transmission: CVT
temmah is on a distinguished road
Wheel alignment?
2016 Forester 2.5L CVT - SubaXtreme Bash Plate
  #117
Unread 19th May 2018, 08:44 AM
scalman scalman is offline
Year: 2001
Transmission: 4eat
I removed front shocks couple times and after with bad wheel alignment i get vibrations from around 70 km/h speed and really bad ones at 100 or higher speed so definetly bad aligment doing that for sure. But i manage to remove vibrations completely with simple home made alignment. No more vibrations for me. Its not because bad camber but front wheels to steering wheel .
Bad wheel balance could make virbations as well.
Mud stuck inside rim.
Just check those.
With bad axle i just got clicking sounds at low speed and nothing on high speeds.
