Go Back   OFFROADSUBARUS.COM > Technical Forums > Under the Bonnet/Hood
  #31
Unread 6th December 2011, 12:18 AM
jonbob jonbob is offline
jonbob is on a distinguished road
Grump,
The head gasket issue with the EJ25 engines was sorted out around end of 2002. The cars affected are typically MY03 Foz and OB with engine built in '02. I had the issue with my old MY03 Forester. My mechanic had the engine out and changed to head gaskets from a later model - all up around $1500 including new timing belt. But it isn't a given that you will have a problem.
Typically you can spot the problem from either coolant or oil (or both) weeping from the head gasket. Most common to start from the underside of the front left hand side of the motor. If you are topping up your coolant regularly, you may have a problem (I was topping up every 5000km from around 110,000km).
If you were using genuine Subaru coolant for that model, it may have contained an additive to stop or slow the leaking.
Hope that helps.
Jon
  #32
Unread 6th December 2011, 07:56 AM
grump's Avatar
grump grump is offline
Senior Member
grump is on a distinguished road
Well that's a relief - thanks Jon.
03 OB
  #33
Unread 7th December 2011, 08:22 AM
eddie351gt's Avatar
eddie351gt eddie351gt is offline
eddie351gt is on a distinguished road
well i got the car serviced, and full saftey check done, my mechanic said that the car is in reall good condition considering the km (323000) but it needs a new tail shaft centre bearing. Ive read that these can be very expensive through subaru,
what other tailshafts (ie liberty wagon) are interchangeable with the outback? and is a manual tailshaft the same length as an auto one?
what have other people done in the past to remedy a *****ty centre bearing? is it worthwhile me getting a custom one peice tail shaft made up? or what would you guys recommend.
cheers lads
Eddie
  #34
Unread 7th August 2017, 02:45 AM
grump's Avatar
Senior Member
Well, nearly 6 years since I posted that.
The OB is presently in TopTorque's workshop getting the leaky head gaskets changed - as well as rings, clutch (still had a dual-mass), radiator and other assorted engine bits. Will cost more than the second hand value of the car, but I reckon it's worth doing, as it's still a nice car.
BTW its done 198,000 km and was built in October 2002, so it falls within the dodgy gasket range mentioned a few posts above.
03 OB
  #35
Unread 7th August 2017, 02:59 AM
Ratbag's Avatar
Ratbag Ratbag is offline
Year: MY06, MY10
Model: Forester SG & SH
Both our EJ253 engine Foresters have slightly weeping head gaskets, oil only to outside of engine. They are MY06 and MY10. Neither engine uses a measurable amount of oil between oil changes - 24 months/12,000 Kms. I use Shell Helix Ultra 5W-40 fully synthetic in both engines.
  #36
Unread 7th August 2017, 07:49 AM
ateday ateday is offline
Year: 2002
Model: MY03 Forester
Transmission: 5 sp manual
I must have fluked a good `un.
MY 03 15 years old from new, 354000 km original motor, head gaskets and engine oil seals.
Many other bits have failed over the years. Some on a, more or less, regular basis such as boots, radiators and clutch thrust bearings.
Otherwise motor runs smoothly and uses a bit of oil between changes but not a lot. I estimate about 500 mls max between my 5000 km change intervals. Although a small leak from rear engine oil seal.
Needs now, I think, a new alternator and a new front passenger inner CV joint. Costs more in repairs and services than it is worth......
  #37
Unread 7th August 2017, 07:09 PM
grump's Avatar
Senior Member
Yes, it was only leaking on the outside afaik. Oil from the left bank, coolant from the right.
03 OB
  #38
Unread 22nd December 2017, 01:27 AM
grump's Avatar
Senior Member
Now 4 and a bit months later ... after the engine work and clurch replacement, the car is, well, different. Some bits are better, some not.
The good bits:
the car is easier to launch smoothly ... no more clutch shudder or chatter.
The car seems to have quite a bit more go.
The not so good bits:
The engine has lost some off-idle smoothness ... where it would pull away quite well from 40kph on light throttle, it now has a harsh vibration under those conditions if I'm not careful.
There is much more transmission backlash on the over-run ... quite uncomfortable if not controlled.
However, the overall driving is better, particularly the mid range response. However, its no longer the lovely smooth car that I bought. I dont think there is any point in taking it back to the mechanics, as I dont think they'd be to do much.
03 OB
  #39
Unread 22nd December 2017, 02:30 AM
duncanm's Avatar
duncanm duncanm is offline
Year: 1998
Transmission: 5MT DR
If it clunks on and off throttle, check the rear diff bushes. Driveline slack/clunking could also be engine &/or trans mounts. Both relatively simple to replace.
All the rubber bushings and mounts will be reaching their end of life.. so its a good place to start looking.
My '99 BH is now on about 300k (except the engine). Replacing all the rear suspension bushes made a big difference, as did the front lower control arm rear ones about 100k ago. Other big improvements were rear diff bushes (I got lazy and shoved some poly inserts in the existing busted ones instead of swapping over), and filling the space in my gearbox mount with polyurethane sealant.
It still drives well, no clunks, rattles or squeaks. Probably due for new struts/shocks at some point (still on originals).
By 200k, my last car (Nissan) was absolutely falling to pieces.
TT Outback
  #40
Unread 30th May 2018, 09:35 AM
grump's Avatar
Senior Member
It does not clunk - it's more like a reverse kangaroo hop - ie when slowing down, not when starting off.
03 OB
