  #541
Unread 3rd June 2018, 05:09 PM
Rally's Avatar
Rally Rally is offline
Year: 2004
not so much car suspension specialists as motorsport suspension specialists.
  #542
Unread 3rd June 2018, 09:00 PM
Ben Up North's Avatar
can only hope to improve
Year: 2004 | 1992
Transmission: 5MT D/R | 4EAT
Sounds like the price of two lockers..
  #543
Unread 4th June 2018, 09:00 AM
jf1sf5's Avatar
jf1sf5 jf1sf5 is offline
.....or 5 Outbacks H6 for Scalman
Subversive...
  #544
Unread 4th June 2018, 10:49 AM
scalman scalman is online now
Year: 2001
Transmission: 4eat
1 would be enough for me .
  #545
Unread 5th June 2018, 01:48 AM
Dulagarl's Avatar
Dulagarl Dulagarl is offline
Year: 2000
Model: EZ30R Forester
No, I wouldn't be doing this myself. Rather, I would engage the services of a suspension specialist.
Talk to Ralf at TruTrack in Melbourne. Great suspension shop who did my custom rear struts (koni inserts, raised spring perches, reinforced strut body) and custom springs. Ask him about the suspension setup on the blue Forester that belongs to Greg.
http://www.trutrack.com.au/
Originally Posted by Dulagarl View Post
Instead of bolting them at the bottom, they will sit on a spacer to lift them. The inserts will be held in place by a collet with a screw top at the top. Here's the spacer:
here you can see the modified carrier: a collet at the bottom has been welded in place. You can also see where the spring perch as been moved:
Finally, you can see the carrier with the strut in it, and the collet that will be fitted to the top.
Won't be putting the King springs back in. Instead, I am getting custom springs made. The rear springs will be progressive, and allow a decent ride when unloaded, but the rear will take up about 20mm when loaded and the spring will be harder, if that makes sense.
Really looking forward to this...
  #546
Unread 4th July 2018, 05:44 AM
Rally's Avatar
Year: 2004
I recently bought a new compressor. Well, a mate bought it for me. Only when I got it home did I realise what I got myself in for. First of all, it’s pretty heavy. And they rate it at 300l an hour. Which explains why it draws 90 amps!!! I had to discard the wiring from the old compressor and go heavy duty. 100 amp circuit breaker, 175amp Anderson plug, and battery cables. Yes, it’s OTT and had I followed normal practice I would have got something smaller. But at 300l an hour, it won’t take long to air up!
  #547
Unread 4th July 2018, 06:46 AM
it wont take long to air up!
or blow up
  #548
Unread 11th September 2018, 03:42 AM
Rally's Avatar
Year: 2004
An update on the air compressor. Geez that draws some current. Rated at 90 amps, it managed to trip the 100 amp circuit breaker a few times. I thought the 90 amps was a peak load. Instead, it might be more than that. Or maybe the circuit breaker is not quite 100 amps. Either way, when it is working it pumps up pretty quickly. I have decided to use the tyre inflator from home, easier to use I hope.
The rear diff locker got a really serious workout. I was in a deep mud and water bath, and due to the topography I had to drive up the steep sides at an angle. It would have been impossible without the locker. Despite the mud, the RE002’s were once again up to the task.
  #549
Unread 11th September 2018, 06:33 AM
NachaLuva's Avatar
The rear diff locker got a really serious workout. I was in a deep mud and water bath, and due to the topography I had to drive up the steep sides at an angle. It would have been impossible without the locker. Despite the mud, the RE002s were once again up to the task.
Video?
  #550
Unread 11th September 2018, 06:49 AM
Rally's Avatar
Year: 2004
Waiting, waiting, waiting. I have asked, hopefully one day. Soon.
