Unread 15th November 2014, 06:47 PM
silver's Avatar
silver silver is offline
silver is on a distinguished road
Default Whats your thoughts??
My speedo/odometer stopped working therefore my cruise control won't work either...the rest of the dash is fine...what are your thoughts please??
Unread 15th November 2014, 09:31 PM
zippo zippo is offline
Guest
Year: 2007
Model: Forester X
zippo is on a distinguished road
Options (based on SG) are limited to:
Speed sensor fail
Cluster microprocessor fail
Wiring loom (between above) fail.
So have humans been near any of these just prior to the failure? Changed gearbox recently?
Unread 16th November 2014, 01:45 AM
silver's Avatar
Forgot I had this.
P0502 Vehicle Speed Sensor A Circuit Low.
If it is the 'speed sensor' what does this entail to fix the problem? Do you think it is possible to get a part from a wrecker??
Thanks.
Unread 16th November 2014, 05:46 AM
Guest
Year: 2007
Model: Forester X
I've only ever enquired once at a wrecker, for an SG one - and they said "it's part of the box". But don't let that stop you trying.
Before going too far down that path, that code simply means the cluster micro isn't registering a pulse train from the sensor. Could be a connection issue. If you can borrow one from a fellow forum member to try, that'll be the best (i.e. cheapest) diagnostic path.
Unread 16th November 2014, 06:57 AM
Manual or auto? MT it just unscrews from the top of the box.
Unread 16th November 2014, 07:06 AM
Guest
Year: 2007
Model: Forester X
Yes, easily removed and there's harness connector at the rear of the engine, but wreckers don't like having a box with a hole in it. That's why borrowing one to try is the best way forward.
Unread 16th November 2014, 09:08 PM
silver's Avatar
Well I have had a poke around and found a couple of things but not sure what is what. It would be better if I had a hoist but I don't. I can't really tell what's what. Is it passenger side or drivers?
I can't swap with anyone around here....once (if) I get it out and there are not many wreckers I could test out....any idea what the OZ going price is???
I can't get a clear enough image of the pic above. I'll try youtube also.
Unread 16th November 2014, 09:37 PM
silver's Avatar
Had another look and reckon I have found it. Black looking thing. Had a fiddle with the connector but can't really good a good grasp of anything. I'll jack it up and take off the wheel and see what I can do. I'll price one at the filthy Subaru stealer later in the week.
Unread 17th November 2014, 01:48 AM
Venom Venom is offline
Venom is on a distinguished road
Exact same symptoms to when my speed sensor failed. I just pulled one out of a car at a pick a part joint, had to go to 3 places to find one because they were either auto, the sensor was missing or the whole gearbox was gone.
Unread 17th November 2014, 02:24 AM
silver's Avatar
Not any wreckers close to me. I'll see what I can find out. I assume it has to be from an identical motor.....mine is MY05 manual...approx. 113kw model.
