ateday
- Joined
- May 2, 2014
- Messages
- 972
- Car Year
- 2002
- Car Model
- MY03 Forester
- Transmission
- 5 sp manual, 1.59 LR
I suspect that, unlifted, a 65 profile would not fit at all well on the older MY03`s.
If you can get smaller rims to fit, this is the best solution.Now I'm thinking 15in wheels instead and just match the ratio of wall to my current overall radius and then i'll end upwith thicker tires.
Don't forget to hit up @NachaLuva (SubieLift Oz) when you're ready to shove a lift in the beast. Excellent quality kit.
Just the standard 16" steelies with 215/65 (D697) on them. Have them on my camper trailer too for redundancy purposes (4 spares!) so it's getting a bit pricey to swap them all for a different size...What are you running?
Oh.. didn't read proper. thought bluesubaru was on 16" already. What Kevin said!You may get 16s on it without too much difficulty.
Haven't had any problems at all with the 65s off-road, haven't done any sand work with them.
Oh! 18! for some reason I thought you were on 17 as standard.Thanks folks. Yeah I've seen 15s in the US. 16 might be better then. I am on stock, so its 18 for me now, stock everything.
Subaru steelies (I've got the poverty pack 2005) & Bridgestone D697 (Dueler A/T). OK on the road but tend to be a bit slippy in the wet (according to Bridgestone they're meant to be pretty good) , but haven't driven any other A/T so they might all be a bit slippy. Main reason for using Bridgestone is that I have family with Bridgestone so I can get them pretty cheap any time I need them. They regularly do specials which almost match the price I get them at.What brand wheel and tire do you have?
I reckon you could go bigger. Unless there's no space to the spring perch as standard, because @bluesubaru 's configuration is only 10mm radius larger, assuming he's running 225/55R18 at the moment, then it's no closer to the strut than before either (give a mm).245 might be getting very close to the front spring perch?
