  #11
Unread 30th November 2017, 02:16 AM
I reckon with the lift and increased rate they will do the job.
I've not be able to find any info for self-leveling in 2016 OBs so seems it doesn't have it; maybe it was dropped when they changed the rear suspension to double wishbone instead of struts?
MY'97 Outback RIP
  #12
Unread 30th November 2017, 09:34 AM
PauSum's Avatar
PauSum PauSum is online now
Year: 2005 and 2014
Model: Forester and Outback
Transmission: 5 speed manual and 7 speed CVT
PauSum is on a distinguished road
Subaru might have dropped the self-leveling rear suspension in recent models.
It clearly indicates in my MY14 Manual that it still has it
MY06 Forester XS manual
MY14 Outback 2.0D CVT
  #13
Unread 30th November 2017, 04:54 PM
@jmsyd will have to be absolutely sure as it would be a different spring if self-leveling; although Kings have made no mention of it as an option and nor do they say that the KSRS-56 does not suit self-leveling as they have done with other models.
MY'97 Outback RIP
  #14
Unread 30th November 2017, 07:01 PM
NachaLuva's Avatar
Originally Posted by jmsyd View Post
I don't know -- how can you tell?
The SLS strut looks very different, it is a very large diameter. The non SLS strut has straight sides, the SLS is bulbous. It sounds like it might be non SLS now, if you're not sure post up a photo & we'll be able to tell you.
Kings responded with this: "Our KSRS-56 will be an approx 15-20mm lift and 20% stiffer in rate when fitted to the 5th gen Outback."
That sounds good. I thought it was more than that but 15-20mm will work well.
20% will stiffen up the rear, let us know what it's like unloaded
  #15
Unread 30th November 2017, 08:36 PM
jmsyd jmsyd is offline
Year: 2016
Model: Outback
Transmission: CVT
jmsyd is on a distinguished road
Will these springs work ok with one of your lift kits? Or would you recommend stock springs?
Last edited by Kevin; 30th November 2017 at 10:46 PM. Reason: Unnecessary use of Quote
  #16
Unread 30th November 2017, 08:38 PM
duncanm's Avatar
duncanm duncanm is offline
Year: 1998
Transmission: 5MT DR
What does 20% stiffer in rate buy someone in terms of preventing sag under load?
perhaps not surprisingly, 20%.
If the car currently drops 50mm under a given load, it'll drop 40mm with 20% stiffer springs.
TT Outback
  #17
Unread 30th November 2017, 08:59 PM
NachaLuva's Avatar
Yes it will work fine with my lift kit, but I would do 2" all round not 2.5" rear. I've had lots of people use HD rear springs in conjunction with a 2" lift, it's very popular for Foresters & I'm sure I've had a few people do it with an Outback too. Both Foresters & Outbacks are known for their bum sag lol
If you're going to regularly load up the rear I would suggest the raised springs. 15-20mm isn't very much & might end up slightly higher unloaded & level when loaded
