  #71
Unread 8th December 2017, 01:17 PM
scalman scalman is offline
Year: 2001
Transmission: 4eat
or you starting drive alone with lots of thinking and preplaning and learn as you go. in time i got my outback i still didin't found with who to drive in my area. so i do it alone everytime just , look, go explore on foot if needed then come back and drive track.
its not same beeing noob in it and being stupid and do reckless things
  #72
Unread 12th December 2017, 01:10 AM
Year: 2013 / 2008
Transmission: 5EAT
Going back...
that's a pretty old link.
When it comes to LT tires, there are civilized enough, plenty tough enough tires for those who can fit them, particularly well reviewed MT are Goodyear Wrangler MT/R with kevlar in the sidewall, BFG TA KM2, and Toyo Open Country MT. Among the ATs, the BFG TA KO and KO2 get rave professional reviews and let's not forget that KO/2s can be used for Baja racing--and that is one tough desert environment. They may be AT, but their predecessor was renowned for toughness and the KO2 are stronger (plus they grip better).
Any of the above tires will fare well "off track" wherever that is actually legal (and even if legal, it would be ethically questionable). Sure, you will want tires with even bigger blocks, even deeper tread, and beadlock wheels so they could be run at 5 psi--and under. But none of this is Subaru territory.
If you want tires for a big mud truck, then there are bias ply options, too. These kind of tires are not available in car sizes and they are only appropriate for toys used in the harshest of terrain.
A factor that has not yet been mentioned is braking on dirt. Tires with deeper tread will brake better in the dirt than tires with shallow tread.
18 4R TRDOP, 08 Tribeca
(13H6OB 2" SLOz, 06 B9)
  #73
Unread 12th December 2017, 02:23 AM
NachaLuva's Avatar
The Aussie outback is huuuge! Imagine an area 80% the size of continental US with a tiny population. According to Google, it's 2.5 million square miles in area (continental US is 2.9 million square miles) and is home to less than 700,000 people at 0.1 per square km. People are outnumbered by kangaroos by at least 10:1!! Lol.
There are almost no sealed roads in the outback & not many formal unsealed roads/tracks compared to the US, many are informal tracks connecting local aboriginal communities
In land that is owned by the traditional owners (aborigines), permits must be gained first which will have conditions including remaining on the tracks. But if permission is given (in writing of course) off-track would be legal.
In most other areas of the outback, off-track travelling is totally legal afaik. There's simply nothing there
From our Subaru Extreme trip last year, this is in the Simpson Desert. This desert is bigger than Texas, literally:
Yes esp on wet clay. Driving down a steep wet clay track on ATs or muddies can be challenging, doing it on road tyres would simply be asking for trouble & the chances of staying on the track would be limited
  #74
Unread 12th December 2017, 02:59 AM
Year: 2013 / 2008
Transmission: 5EAT
Ha! Good point, if there is nothing there.
  #75
Unread 24th July 2018, 02:52 AM
duncanm's Avatar
duncanm duncanm is offline
Year: 1998
Transmission: 5MT DR
just to re-ignite this discussion..
finally got a flat - after about 10 years of ownership / 4 sets of tyres and zero flats - on the weekend.
Need-replacing-aged Kumho KU31's on the Araluen Rd.
Quick inspection says something about 1/4" wide and sharp went right through the fat part of the tread (ie: not between tread blocks). No evidence of what it was on the outside, so it either didn't stick in, or maybe it broke off inside.
No matter -- I needed new tyres.
On went the unknown-aged geosquealer spare
TT Outback
  #76
Unread 24th July 2018, 05:50 AM
havachat's Avatar
havachat havachat is offline
Year: 2002
Model: Forester SG
Wack a plug in they work a treat. I had a puncture at The Flinders Ranges, put a plug in and when I got home took it to Bob Jane to get a pro repair. My Bob Jane dealer looked at my repair and said it was as good as the repairs they do so not to waste my money!
  #77
Unread 24th July 2018, 06:18 AM
NachaLuva's Avatar
Oh no not a Geosqealer
Oh well, good time to get some decent tyres for more grip. If you don't like Geolandar G015, Toyo Open Country ATs are becoming popular. Or Falken Wildpeak ATs & Bridgestone D697
  #78
Unread 24th July 2018, 06:53 AM
Rally's Avatar
Rally Rally is offline
Year: 2004
What did Kumho replace the 31 with?
  #79
Unread 24th July 2018, 07:25 AM
duncanm's Avatar
Year: 1998
All four tyres are getting near legal limits.. was time for a new set of donuts anyway.
Alignment also needs doing as I recently replaced the rear suspension rubbers and swapped in a pair of alloy front LCA's I picked up at the wreckers cheap.
Booked for some rubber and alignment Thursday. Sticky road tyres, I'm afraid for you AT types.
No idea what KU31 was replaced with. They were 'ecxtas' and I wasn't real happy with them. NOS, slippery in the wet from new.
TT Outback
  #80
Unread 24th July 2018, 08:19 AM
Rally's Avatar
Year: 2004
RE003’s?
