  #21
Unread 22nd August 2016, 04:16 AM
Ratbag's Avatar
Ratbag Ratbag is offline
Year: MY06, MY10
Model: Forester SG & SH
Pedders catalogue for our models (SG, 2002-2008) is here:
http://www.pedders.com.au/catalogue/...-2008-sg-model
  #22
Unread 22nd August 2016, 04:17 AM
NachaLuva's Avatar
If that's for supply & fit front & rear then those are good prices!
  #23
Unread 22nd August 2016, 05:03 AM
Vert Vert is offline
Year: 2007
Model: Forester x
Transmission: Auto
Vert is on a distinguished road
Lol I wish supply fit and alignment rear only...
  #24
Unread 22nd August 2016, 07:19 AM
For the extra $50 I'd go with kyb / kings at Sydney Suspension (AKA Wholesale Suspension) - they've done all the work on my Foz custom suspension.
MY'97 Outback RIP
  #25
Unread 22nd August 2016, 10:56 AM
NachaLuva's Avatar
I'd go KYB/Kings too, it's a tried & tested combination. For just rear seems a bit expensive though. My breakdown would be (estimates)
pair King springs $150
pair KYB struts $350
labour (1-1.5hrs) $150?
alignment $100-120
Total ~$750
If they do a good job (Kevin's recommendation is good) then it might be worth paying the extra
  #26
Unread 23rd August 2016, 08:28 AM
Year: 2007
Model: Forester x
Transmission: Auto
Yeah it's a fair bit of dosh for it. Could save some on the swheel alignment but not think it would be a saving in the longer run.
  #27
Unread 24th August 2016, 06:55 AM
Ratbag's Avatar
Year: MY06, MY10
^ our Subies are very, very badly affected by the slightest abnormality in alignment.
When I bought Roo2, its wheels were all within OEM specs, but all pointing in different directions. It handled like a canal barge!
With a full alignment (and chassis squareness check) and new tyres, it handles nearly as well as my '93 Impreza did. That's after the Pedders rear spring units were fitted, and another alignment done.
I will put in one of Nacha's 1" lift kits soon, and will have the alignment checked after that's done.
  #28
Unread 4th September 2016, 03:32 AM
Year: 2007
Model: Forester x
Transmission: Auto
Sorry all been pretty busy to do a post.
From what I can see they are not self levelling struts.
So would I be right in thinking in this case could it be just that the springs have sagged and it may just need replacement springs rather then a full overhaul with the struts.
Is there any way I could check this out first without removing the struts?
Cheers all for the help so far.
  #29
Unread 4th September 2016, 05:09 AM
Do you know how old or distance travelled on the struts? The reason I ask is that if they're old then you might as well have them replaced at the same time as the springs rather than have to pay again for the labour involved in pulling everything apart.
MY'97 Outback RIP
  #30
Unread 4th September 2016, 05:18 AM
Year: 2007
Model: Forester x
Transmission: Auto
Hello Kevin,
I am on the 167,000 mark.
So they are getting on a bit.
Second owner. No major repairs on vehicle other then full timing belt kit replaced on its major service and no visible underbody damage So believe been treated reasonably
Tags
sag, suspension
