  #41
Unread 27th August 2015, 07:18 PM
ateday ateday is offline
Year: 2002
Model: MY03 Forester
Transmission: 5 sp manual
I suspect that, unlifted, a 65 profile would not fit at all well on the older MY03`s.
  #42
Unread 27th August 2015, 10:01 PM
kiwifoz's Avatar
kiwifoz kiwifoz is offline
Year: 1997
Model: Nissan Terrano
Transmission: 4sp auto, ATTESA PT4WD, D/R
kiwifoz is on a distinguished road
I ran 215/65r16 Bridgestone Dueler D697 AT on my old 2002 MY03 SG for a short while before I lifted it on raised King Springs only. Never had a single rub and my old suspension was shot (quite sagged, especially in the back).
Ateday I suspect yours may rub because the 40mm lift will push the front wheel further back in its arc, meaning it will be closer to the rear of the wheel arch?
The D697 DID NOT fit in my wheel well fully inflated. However a Kumho KH18 in 215/65r16 did, just. These are onroad tyres though and I wouldn't recommend for even slight 4x4ing.
Here's a pic of the 697s with no lift:
Front right wheel arch clearance with chains
Rear strut clearance with chains
Rear arch clearance with chains
As you can see, with OEM +48 offset wheels there's heaps of clearance even on saggy suspension. I could even fit chains front and rear (although they just touched the front spring perch but still rotated). Rear was fine with chains, over 1cm of clearance everywhere.
Hope this helps
Just for comparison here's one post-lift with same tyres:
As far as the tyre themselves is concerned, I really like the D697 and am running them on the Foz's replacement. Looks different to a 'traditonal' AT like the BFG but still works well offroad, it sheds mud relatively well due to the tapered blocks and relatively open cut. Some people say they're hard and not grippy but I feel they stuck better in the dry than the KH18s I ran back to back as road tyres, and were comparable in the wet.
Do note though that the 215/65r16 is a commercial rated tyre - it has heavy construction and you do pay a weight/performance price. I noticed a definite decrease in acceleration running D697s on OEM steel wheels, vs the KH18s on WRX alloys, despite both being 215/65r16.
In saying this it means you're less likely to get a puncture offroad! They are nice tyres, more aggressive than the Geolandar ATS and cheaper too. I'd have to recommend, even with no lift.
RIP 2002 Forester, 2009 GV
1997 Nissan Terrano
  #43
Unread 28th August 2015, 12:00 AM
I also ran 21565R16 before changing to 15" wheels. The spare has to be deflated to about 10-15 psi and the wheel well "modified" (i.e. bashed with a big lump of wood)
MY'97 Outback RIP
  #44
Unread 28th August 2015, 03:41 AM
Year: 2002
KF, you could be right `cause that`s where it rubs. Have had to cut the tacky placky inner guard protector back a bit.
Kevin, I didn`t bash my wheel well but cut the black sound moulded padding away a bit. Still needs deflating though.
  #45
Unread 14th January 2017, 10:57 PM
andymccauley andymccauley is offline
Year: 81
Model: DL
Transmission: Manual 4spd
andymccauley is on a distinguished road
What's the widest 15-16" 6 lug rims anyone is running on an old DL. After lift I'm thinking of running some 15x8 but was thinking 10 wide might add some more poke
  #46
Unread 11th April 2017, 10:45 AM
dirty4130 dirty4130 is offline
Year: 1999
Model: Forester L
Transmission: Auto
dirty4130 is on a distinguished road
Hi, Feel free to move my question, as I'm not sure this is the correct place for it. I've seen a lot of conflicting opinions about whether a 215/75R15 tire would fit the 1st generation Forester (99 Forester L, completely stock, came with 15" wheels). I am looking into getting General Grabber AT2s and the sizing options seem to be 205/75/R15 or 215/75R15. I am pretty certain the 205's would fit, but less confident that the 215's would fit. Currently the car has 215/70/R15 no-name tires on it. Any suggestions?
