  #101
Unread 11th June 2018, 06:13 PM
jf1sf5's Avatar
jf1sf5 jf1sf5 is offline
They must be slicks !
Subversive...
  #102
Unread 11th June 2018, 07:20 PM
Rally's Avatar
Rally Rally is offline
Year: 2004
You all know how I like traction
  #103
Unread 11th June 2018, 07:35 PM
Year: 2013 / 2008
Transmission: 5EAT
2215? Now we know why Rally gets through everything. The locker was just a ruse!
18 4R TRDOP, 08 Tribeca
(13H6OB 2" SLOz, 06 B9)
  #104
Unread 11th June 2018, 07:50 PM
MY'97 Outback RIP
  #105
Unread 26th October 2018, 08:16 AM
ABFoz ABFoz is offline
Year: 2005
Model: Forester XS
Transmission: 4EAT
ABFoz is on a distinguished road
What Tyre Brand are you on? Yokohama G015
What Size are they? 215/65 R16
What type are they - wet/dry Both
Are they grippy or not? They are very grippy on gravel; Wet grip is OK;
Are they noisy or quiet? These are quiet for AT tyres; The sound is no louder than directional road tyres.
Are they good for offroad or just onroad use? These are very good for both;
On the road, they have good enough grip; On mud and at 25psi, these perform exceptionally. I drive by getting as much traction on the tyres instead of flooring it; On extremely soft sand, I was able to test the set initially at 20psi and was able to get up the dunes with less momentum than most trucks in the area. At 15spi, there is a huge traction difference; On rocks and mud, I run 25psi and I get a lot of traction with moderate throttling; I always run 28psi on corrugations with mild to moderate undulations and, as with the other terrains, I get a lot of traction.
The grip differential is closer with these tyres than with road tyres for tarmac and gravel grip - Road tyres, generally, are extra grippy on black top and somewhat much less grippy on gravel. These tyres have OK grip on black top but with increased traction on gravel. I am assuming it's to do with their compound.
What Life span are you getting out of them? I have just run 4000km with these and they still look relatively new. I will keep this updated after 1000km.
Do you like them or not really? I like them a lot. I now understand why this model is the go-to for most Subaruers. The price/traction ratio is its main strength.
I get a much more decent fuel consumption than the previous HiFlys.
I sold the 17s, as well as the 16" HiFlys that came with the 16" SH Enkeis, by the way.
  #106
Unread 26th October 2018, 08:28 AM
Rally's Avatar
Year: 2004
Originally Posted by ABFoz View Post
What Tyre Brand are you on? Bridgestone D697
What Size are they? 265/65 R17
Are they grippy or not? Brand new, too early to say.
Are they noisy or quiet? Quiet, at least on the freeway. How they go oncoarse chip bitumen I will find out
Are they good for offroad or just onroad use? Hopefully they will be good for off road use, I don't expect much on road.
What Life span are you getting out of them? Done about 50kms, no idea.
Do you like them or not really? Let's see if I get a puncture on my first trip
[/I]
This is for the Ranger, not the Forrie.
  #107
Unread 26th October 2018, 08:41 AM
Year: 2005
Model: Forester XS
Transmission: 4EAT
Keep us updated on your set @Rally. I am supposed to go with the same model but the Bridgestone dealer seemed kind of reluctant to put those on my SG5. They are in the same price bracket last time I checked. The shop where I got the G015s from was much easier to deal with. Cheers.
  #108
Unread 26th October 2018, 09:27 PM
Year: 2010
Transmission: Auto
When I got my SH as a new car it was fitted with Bridgestone Dueller HT
What Tyre Brand are you on? Bridgestone Dueller HT
What Size are they? 215/65 R16 running at 38 psi
Are they grippy or not? Not too bad.
Are they noisy or quiet? I didn't notice excessive noise
Are they good for offroad or just onroad use? I did't take them off road except for a few hundred Km of formed gravel road but on bitumen they seemed fine to me
What Life span are you getting out of them? I changed them before it was necessary and they had 89,000 on them at the time.
Do you like them or not really? They were OK but not special.
Because I wasn't into off roading and it was a company car doing big highway mileage I decided to put more road oriented tyres on it so I got a new set.
What Tyre Brand are you on? Michelin Energy Saver
Are they grippy or not? Much better than the Bridgestone OEM in both wet and dry.
Are they noisy or quiet? Significantly quieter than the bridgestone OEM
Are they good for offroad or just onroad use? I had these on when I started to get interested in off road driving and used them on sand with excellent results but they were really a road tyre and that was where they shone.
What Life span are you getting out of them? They had 70,000 Km on them when I swapped them for a set of rims and tyres. They looked to have about another 20,000 L in them at that stage.
Do you like them or not really? They were great for driving on the highway but Michelins have a reputation for soft sidewalls so I wouldn't take them on rough, rocky tracks.
I took a more "off road" approach with my next set of tyres.
What Tyre Brand are you on? Toyo Open Country AT
What Size are they? 215/70 R16 running at 34 psi
What type are they - M+S
Are they grippy or not? They are very grippy on dirt but less so on bitumen;
Are they noisy or quiet? Quiet for AT tyres; The sound is louder than the Michelins but comparable with the Bridgestone HTs.
Are they good for offroad or just onroad use? I'm happy with their off-road performance, keeping in mind they are a compromise tyre that gives reasonable performance on all kinds of off road surfaces but not outstanding on any. Where their performance is a bit concerning is on wet bitumen. Braking is fine, but lateral grip when cornering on wet bitumen is much lower than either of the tyres I have run previously. It means I have had to moderate my speed when cornering in the wet.
  #109
Unread 27th October 2018, 04:06 AM
Gee 38 PSI (cold) seems high! Did you check their PSI when hot?
MY'97 Outback RIP
  #110
Unread 27th October 2018, 04:18 AM
Year: 2010
Transmission: Auto
I didn't check them hot but they seems very harsh on the road so dropped them back.
