Go Back   OFFROADSUBARUS.COM > Technical Forums > Suspension, Handling and Brakes
Unread 30th November 2017, 02:16 AM
I reckon with the lift and increased rate they will do the job.
I've not be able to find any info for self-leveling in 2016 OBs so seems it doesn't have it; maybe it was dropped when they changed the rear suspension to double wishbone instead of struts?
Unread 30th November 2017, 09:34 AM
PauSum's Avatar
PauSum PauSum is offline
Year: 2005 and 2014
Model: Forester and Outback
Subaru might have dropped the self-leveling rear suspension in recent models.
It clearly indicates in my MY14 Manual that it still has it
MY06 Forester XS manual
MY14 Outback 2.0D CVT
Unread 30th November 2017, 04:54 PM
@jmsyd will have to be absolutely sure as it would be a different spring if self-leveling; although Kings have made no mention of it as an option and nor do they say that the KSRS-56 does not suit self-leveling as they have done with other models.
Unread 30th November 2017, 07:01 PM
Originally Posted by jmsyd View Post
I don't know -- how can you tell?
The SLS strut looks very different, it is a very large diameter. The non SLS strut has straight sides, the SLS is bulbous. It sounds like it might be non SLS now, if you're not sure post up a photo & we'll be able to tell you.
Kings responded with this: "Our KSRS-56 will be an approx 15-20mm lift and 20% stiffer in rate when fitted to the 5th gen Outback."
That sounds good. I thought it was more than that but 15-20mm will work well.
20% will stiffen up the rear, let us know what it's like unloaded
  #15
Unread 30th November 2017, 08:36 PM
jmsyd jmsyd is offline
Year: 2016
Model: Outback
jmsyd is on a distinguished road
Will these springs work ok with one of your lift kits? Or would you recommend stock springs?
Last edited by Kevin; 30th November 2017 at 10:46 PM. Reason: Unnecessary use of Quote
  #16
Unread 30th November 2017, 08:38 PM
What does 20% stiffer in rate buy someone in terms of preventing sag under load?
perhaps not surprisingly, 20%.
If the car currently drops 50mm under a given load, it'll drop 40mm with 20% stiffer springs.
  #17
Unread 30th November 2017, 08:59 PM
Yes it will work fine with my lift kit, but I would do 2" all round not 2.5" rear. I've had lots of people use HD rear springs in conjunction with a 2" lift, it's very popular for Foresters & I'm sure I've had a few people do it with an Outback too. Both Foresters & Outbacks are known for their bum sag lol
If you're going to regularly load up the rear I would suggest the raised springs. 15-20mm isn't very much & might end up slightly higher unloaded & level when loaded
