Unread 1st July 2017, 08:34 AM
Default flat tire
Had a flat tire because of a faulty valve yesterday and the spare is a stock 205/70 15 versus the 215/70 16 I'm actually running...
Drove 30 km without any issue thanks to the Quaife helicals front and rear and the epicycloidal center on manual mode (DCCD).
Unread 2nd July 2017, 05:28 AM
Very handy!
Unread 2nd July 2017, 10:00 PM
Hope that doesn't do the diffs any damage
Unread 3rd July 2017, 07:51 AM
It shouldn't.
Helicals work like open diffs most of the time like when no slippage occurs or when one wheel is in the air.
And the DCCD also works like an open diff but sends more torque to the rear than to the front (65/35) thanks to the epicycloidal design but can be "locked" (50/50) thanks to the electromagnetic manually controlled clutches
So as far as I know, nothing should heat up or break, I have no more Vlsd's like oem (center/rear) nor Clsd's like Cusco, Kaaz or STI (front/rear)
