taza
Want better articulation offroad but don't want to loose your onroad handling then quick disconnects are an option for you!
They replace the bolts that connect your swaybars to your end links. In a Subaru articulation is very limited but when you disconnect or remove your swaybars you can get any one wheel amlost out of the complete wheel arch. This is almost double compared to when they are attached.
I found the idea over at Subaruforester.org and thought I should give it a shot and see how much it actually helps. Well its well worth it.
I didnt want to completely remove my swaybars due to it being illegal in Australia, scares the hell out of you driving onroad, there is alot higher chance of your vehicle rolling when you have to swerve all of a sudden and if you have comprehensive insurance they may not pay you out if your vehicle is in a accident with no swaybars.
It cost me about $30 to put this little kit together. I have been using the rear quick disconnects for about 2months now and not an issue. Only installed the front ones yesterday. I have found that a pair of pliers are handy to pull the R clips out sometimes.
The kit consists of
: x4 3/8" by 2" long Clevis Pins (I had to get these from a bolt specialist)
: a pack of 4mm R Clips
: a pack of 3/8" washers
Here is the front.
The rear
Taza
The kit consists of
Here is the front.
The rear
Taza
