  #81
Unread 15th January 2018, 02:58 PM
scalman scalman is offline
Year: 2001
Transmission: 4eat
im still thinking what would be better there some rubber or cut some gap in tube so it would lock on that side . something to do in front too it would lock there better. maybe put there biiger tube so jack tube would go like inside it .
  #82
Unread 15th January 2018, 03:24 PM
jf1sf5's Avatar
jf1sf5 jf1sf5 is offline
The HiLifts are quite unstable latteraly (had 1 with my Land Rover)
Subversive...
  #83
Unread 15th January 2018, 04:13 PM
Year: 2001
Transmission: 4eat
could be with heavier car maybe more. i tried to lift front and side and car wasnt moving to sides or front at all. i thought its pretty stable. more so then any other jacks that are standard ones.
  #84
Unread 15th January 2018, 04:33 PM
"Lift Mate" is very handy to lift on the wheel: https://hi-lift.com/accessories/lift-mate/
  #85
Unread 17th January 2018, 02:16 PM
Year: 2001
Transmission: 4eat
yes that i will need to. it can be made too. no need to buy it. i love DIY as much as i can stuff. i love to learn, try , experiment with new stuff.
as that maybe
could make it from straps or chain and different type hooks for my aluminum rim.
to make something similar to sold product should not be too hard too
and then something for pullling car. as i understood i need some amount of chain with hooks for pulling, at least mots people pull car with hi lift using chains and not straps. wonder why.
strap would be lighter to carry.is it not strong enough for that job
maybe just straps would work too
im putting pics for myself too to have more ideas whos using what and how and it would work for me and whats not work. i just need as light recovery gear as possible, best no chains at all and less metal things. hi lift is about 13kg so not that bad still.
and then i need some bigger base for it . again simple thing as to put board under it can be metal or wood. could be made more for ground to have better grip or just to flat surface
this one interesting. less meta,l less weight still strong
or that plastic one looks very light and not take much space
most used stuff with hi lift . just something to think of for myself
rubber pad would work best for street garage etc
just i think you don't need to attach stuff to it just to carry as separate layer and put it when you need. more practical. make separate layers from rubber then other as wood board maybe and maybe one from metal and have them with you.
  #86
Unread 18th January 2018, 12:43 AM
1WD Foz 1WD Foz is offline
Year: 98
Transmission: Manual 5 speed
Hey mate,
Great news to hear you got your car out
and a nice new Hi lift I see.... good stuff mate
1WD
  #87
Unread 18th January 2018, 12:55 PM
Year: 2001
Transmission: 4eat
thanks. yh i like hi lift just need make some mods for it so its better fits my needs. but now its sits secure in trunk and don't even moves or makes any sound there.
will make some cover for it. its not hard to make similar to this
  #88
Unread 19th January 2018, 11:28 AM
Year: 2001
Transmission: 4eat
dont you just hate when this happens with handbrake. last week it was weird sound from rear wheels when i start to drive after stop. and it was cold so i didint looked at it before but i knew it was handbrake pins and springs just got off there
and im doing it couple times allready. just after i using handbrake more then minimal it comes off and then i need to change those pins
and new one doesnt look like tey very much for subaru. because they have flat surface on pins so how i must lock them . i just modify them myself
  #89
Unread 20th January 2018, 11:14 AM
Year: 2001
Transmission: 4eat
have some problem with my hi lift .need some ideas from you guys, or with time i will figure out myself. need to change angle of that tube arm or add to it some stuff so my hi lift wont go pushing into door with force when i try to lift side on car.
thats my problem
  #90
Unread 20th January 2018, 04:31 PM
Year: 2013 / 2008
Transmission: 5EAT
That's what I was trying to say, that you MIGHT be able to get a few points for the HiLift. Once I borrowed a neighbor's jack. Took me maybe 2 min to rule it out.
In addition, the HiLIft will be not just a pain in mud, but also dangerous.
18 4R TRDOP, 08 Tribeca
(13H6OB 2" SLOz, 06 B9)
