OFFROADSUBARUS.com
Go Back   OFFROADSUBARUS.com > General Forums > Members Journals
  #121
Old 14th August 2013, 11:12 PM
dellsfozz's Avatar
dellsfozz dellsfozz is offline
Member
dellsfozz is on a distinguished road
Originally Posted by Bigcat View Post
Wow, your car looks incredible!
That's exactly what I want to do with my Foz. I've just put 215/70/16 BFGs on the stock steelies but they look very skinny and tucked under the arches to far, which is a bit disappointing. Have ordered some Enkei rims at 16x7 with a +38 offset to see if that'll fill the arches out a bit, but your car is the look I really wanted, you have an awesome looking vehicle there!
I have a few questions if you don't mind:
So let me get this straight - your lift includes raised Kings and 40mm strut blocks?
Did you have any rubbing with the TT wheels before you put on your 20mm spacers? I had to cut away some of the plastic wheel arch and bash a panel join flat to stop mine rubbing and that's on the stock steelies.
Did you have to replace your studs with extended items when you put your spacers on?
Did you take any pics of when you reworked the arches? I'd love to see how you squeezed those tyres in. And with a +7 offset are you going to fit arch extensions?
Sorry for the 20 questions but I am glued to this thread with awe
John
Hi John(bigcat),
I'm glad and happy that you like my offroad Foz setup. Here's some Q & A for you mate....
Q--So let me get this straight - your lift includes raised Kings and 40mm strut blocks?
A--Yes mate, and also the lift from big 30"BF Goodrich Muddies.
Q--Did you have any rubbing with the TT wheels before you put on your 20mm spacers?
A--The Audi TT wheels is 30 offset so it move the wheel away from the strut and body. I still did the same as you did trimming the plastic inner guard panel beat the panel join. And with the current muddies, I did more panel beating and re-shaping of the front guard close to the front door. i also had to cut and re-shape the rear guard and cut rear bumper off to accomodate the bigger diameter wheel. I will soon be replacing my front lower control arms with STI alloy ones because i can make more caster adjustment from them. Basically, I want to move the front wheel a bit forward because trhe wheel still heat the inner guard under full compression of the front strut. I also have to put 2'' body spacer on the rear trailing arm to kick the rear wheel backward due to the strut top spacer.
Q--Did you have to replace your studs with extended items when you put your spacers on?
A--No, I used a 25mm bolt on wheel spacer just to give that extra clearance of the tyres from the struts spring base, I have to use the original studs and nuts to secure the spacer. The wheel spacer have their own built in studs in them. I fitted them permanently, tighten torque the nuts with sealant, filling any tiny gaps so they look like they are in one piece with the hub. Also paint it with the same color as the hub/disc.
Q--Did you take any pics of when you reworked the arches? I'd love to see how you squeezed those tyres in. And with a +7 offset are you going to fit arch extensions?
A--I have some photos, I will be posting them soon. Yes, I already have some wheel arch extensions for it John, I just need to find some time to fit them.
06 Foz XT-Front&RearBar;Kingys,Cooper215/70
  #122
Old 14th August 2013, 11:19 PM
dellsfozz's Avatar
Member
Originally Posted by Dulagarl View Post
... out of curiosity, what struts are you running?
I used to run the stock struts including rear Self leveling Struts. I have done over 100,000 km. of hard work with them till they finally stuff. Now, I'm using KYB All around, non SLS. It bum sag when I tow my monster trailer, but they are good firm ride.
  #123
Old 14th August 2013, 11:30 PM
dellsfozz's Avatar
Member
Also curious bout the wheel spacers...any effect on wheel bearings, etc? Are they legal in Qld?
The bolt on wheel spacers should no effect on the bearings. My foz done almost 180,000km now and no issues whatsoever. Wheel spacers are not legal in Qld. or any state I think, but we don't have RWC yearly here, that's why my fitment is very discrete or subtle and also use quality bolt on spacers only, not the one that you have to extend your studs.
  #124
Old 14th August 2013, 11:48 PM
PigSti PigSti is offline
on sabbatical
Thumbs up
hehe
  #125
Old 15th August 2013, 12:45 AM
NachaLuva's Avatar
Do you have a link to the ones you used? I found some to suit the Audi wheels but they say not for offroad use
  #126
Old 15th August 2013, 05:03 AM
mr turbo's Avatar
mr turbo mr turbo is offline
Year: MY05
Model: Forry XT
Transmission: manual
Hi guys...I'm back! wow...I miss this forum and would like to apologize for not loggin in for few months. I was affected with the big floods here in Bundaberg, Qld...was so very busy cleaning, rebuilding our property, work, business, etc.
Welcome back dellsfozz
And no need to apologize mate.
Glad to hear that your getting back onto your feet
  #127
Old 15th August 2013, 09:43 PM
Dulagarl's Avatar
Dulagarl Dulagarl is offline
Senior Member
Year: 2000
Model: EZ30R Forester
I used to run the stock struts including rear Self leveling Struts. I have done over 1000,000 km. of hard work with them till they finally stuff. Now, I'm using KYB All around, non SLS. It bum sag when I tow my monster trailer, but they are good firm ride.
Thanks.
I just though they might be something else: being anodised and flashy. Did they come like that or did you tart them up yourself?
  #128
Old 26th October 2017, 02:53 PM
EndZz EndZz is offline
Junior Member
Year: 2008
Model: Forester XT
Transmission: Manual
EndZz is on a distinguished road
Just a few pics playing with rocks
Any of these photos still exist?
  #129
Old 26th October 2017, 04:55 PM
Kevin Kevin is online now
Dellsfozz hasn't been around for 4 years and Photobucket have really screwed up many forums with their greed!
  #130
Old 26th October 2017, 07:59 PM
SquiresSquire SquiresSquire is offline
Member
Year: 2007
Transmission: DR 5MT
SquiresSquire is on a distinguished road
Dellsfozz still frequents FozTrek and Subarus Offroad Australia on Facebook.
I currently run the below plugin in Chrome which fixes the Photobucket Hotlinked images!
https://chrome.google.com/webstore/d...alioapbifiaedg
